NEW - 900 Supersport 1.1 Jelly Bean rooted ROM for Cube U30GT Mini
    On ICS wi-fi works better.
    On ICS whatts app works fine without backup from phone using both wifi/3G.Need install thet voila...it works sending SMS confirmation from a phone...( the number it'a alocated for whatts app)
    ON JB batery life improved (!?)
    ON JB tablet goes of (on my case) then i need to restart-it pressing PWRON.
      When i flash only kernel the boot immage are the same Freaktab logo " aspirins" and a lot of lamps... ...900ss rom mod...
        Re: NEW - 900 Supersport 1.1 Jelly Bean rooted ROM for Cube U30GT Mini
        The image in the kernel is either some Chinese characters or if you flash the version I pasted separately the image will be like my avatar. Once the kernel has loaded the next part of the load process is to load boot.img this contains it's own image, the jelly bean android and the Borg cube. Finally system.IMG begins to load and the boot animation is displayed.
        900Supersport
        freaktab developer
          Yes...really it's youre avatar. After flash only Kernel i don't reboot my tablet. So now i put off then on, a droid green robbot apear...for 1 second then...the rest.
            To me the graphics are just a bit of fun. Any time I have to restart my cube they do put a smile on my face. I'm easily pleased.
            For those that haven't see the image I've embedded in the alternate kernel here it is.
            900Supersport
            freaktab developer
              I have probblems using mx player pro with live streams...
              results no audio.
              With normal player don't work( can't start)
              wi-fi is so poor
              time to time tablet stop itself, need to press PWRON to boot again.
              it'a a common probblem with all JB and all roms.
                My Cube seems to be dead
                I don't understand, could you help me.
                Please take a look to the new thread i created http://www.freaktab.com/showthread.p...-JB-Rooted-rom
                Regard.
                Solved, It was the power adaptor which was out of order.
                Thanks for help.
                  THNX 900 Supersport.
                  Great work, everything worked well, no problems.
                  Great Work!
                    SOLVED
                      I'm really enjoying some of the new Google apps, if you haven't already check out currents, play music and calendar.
                      900Supersport
                      freaktab developer
                        same problems
                        WifE=piccolo08;34672]I have probblems using mx player pro with live streams...
                        results no audio.
                        wi-fi is so poor
                        it'a a common probblem with all JB and all roms.[/QUOTE]
                        Worst wifi than ics
                          whats the difference on new kernel 1.7? is this kernel also can help for wireless on/ off problem cube u30gt's?
                            Corrupt internal nand
                            I flashed this rom (compliments for it by the way) twice. But I keep getting "Damaged SD card" when I select mount SD card under nand flash.
                            Any suggestions?
                              Any suggestions?
                              Same for me. I selected 'format sd card' in the JB dynamic menu (right down menu), sd card was formatted and after all seem to be allright.
                                As mentioned in the first post first boot to system you will get this message, simply format/repair the nand this time and you are done.
                                900Supersport
                                freaktab developer
