I had the same problem and over pass it by doing that
NEW - 900 Supersport 1.1 Jelly Bean rooted ROM for Cube U30GT Mini
Re: NEW - 900 Supersport 1.1 Jelly Bean rooted ROM for Cube U30GT Mini
Greatestpyro good to hear you got the tabs flashed in the end. As a matter of interest what version of windows do you use?900Supersport
freaktab developer
Follow up
I am on Windows 7 64bit and the cable was plugged into the backplate of my PC. Also the cable is 100% good. I flashed my Acer Iconia a510 and then loaded 90GB on it with the same cable, no problems. And just a little advice if people are having issues, here are a few tips I could have used before I started.
1) Once you load the drivers you may need to disconnect the USB cable and reconnect it before windows detects the tab correctly.
2) If you hit the power and the volume+ key at the same time with no cord plugged in it brings up an android icon with his chest open, I was under the false impression that this was the screen I needed to see in order to do the flash, this is incorrect. If the tab is plugged in and you hit the two keys it will stay on a black screen and the loader will indicate that the device is connected this is your queue to start, at least in my case.
3) As long as the data loads the check seems to be irrelevant.
Originally posted by greatestpyro View PostI am on Windows 7 64bit and the cable was plugged into the backplate of my PC. Also the cable is 100% good. I flashed my Acer Iconia a510 and then loaded 90GB on it with the same cable, no problems. And just a little advice if people are having issues, here are a few tips I could have used before I started.
mine is device not registered in win 7. saw yellow triangle at rk 30 device, any help?
problem with flash mod in u30gt mini
Hello. Please solve my problem.
My tablet, is u30gt mini. When the tablet is on, I have no problem with the driver, and the driver can be installed easily. My problem is in flash mode. In this mode, when the tablet is connected to my computer, the computer does not recognize the tablet. ( also if the cable is connected to the tablet, the tablet is not going to flash mode, Should I remove the cable first, then the tablet went into flash mode, connect the cables do ).
Please Help
Yes try putting the tablet into flash mode then connecting to the pc.900Supersport
freaktab developer
Can you not select the unknown device and update the drivers?900Supersport
freaktab developer
Two different sets of drivers are used, one for flashing and one for when the tablet is switched on for ADB.900Supersport
freaktab developer
There are currently 2071 users online. 1 members and 2070 guests.
