NEW - 900 Supersport 1.1 Jelly Bean rooted ROM for Cube U30GT Mini
Re: NEW - 900 Supersport 1.1 Jelly Bean rooted ROM for Cube U30GT Mini
I've never seen that before, does it only happen when on power?900Supersport
freaktab developer
Originally posted by 79kiko View Post
I think that chargers have to make at least 2000mAh so that the tablet works when the charger is connected.
I'd be looking to replace the charger.900Supersport
freaktab developer
Originally posted by a29psx View PostI always get this type of error
[ATTACH=CONFIG]1101[/ATTACH]
I also get similar error with the default flashing program from the original firmware
which read fail in testing or checking my device something
any suggest ?
thanks for your help
the original cable from cube is just rubbish
anyway, thanks 900supersport for this work
Originally posted by Sarunaszx View Posthello, my Cube tablet is arriving and i'm sure i will have to buy a new charger, because it is going to be US type, not EU. What kind of charger could you recommend?
Originally posted by a29psx View Postjust get a wall plug US > EU adapter. I'm sure you can get one from your local electronics store for about $5 or less
Originally posted by Sarunaszx View PostYeah, that would be a solution.. but then the charger will get really big, uncomfortable for carrying it. Besides, I have heard that original charger is bad...
My original charger is acceptable, not getting hot during charging
and I think the DC-in plug is not a popular style so it is not easy to find
if you're realy want to get another charger, make sure to get a 2.5amp at least
I'm in trouble
I followed your instructions to the letter. I have three of these tablets that I need to root. Initially I had some issues with the drivers and booting into the flash mode but sorted that out. Got the first tablet in flash mode, erased the NAND, all is good, then on write flash it wrote the entire 535539K then when it went to check the data it failed at 52K. I was unable to do anything so I unplugged it and turned it on. It went to Clockwork and did everything as expected and worked perfectly. It didn't go as planned but it worked correctly and that's all that matters.
Tablet #2- After the first one acted weird I was hesitant but began the same procedure for number 2. The NAND erase went fine. The flash got screwed up while writing not even 20% into it. What can I do? It won't even turn on now. I need to fix this. The only good news is that the device is still showing up as Found in your program.
UPDATE: So after it going all half brick on me it actually allowed me to erase NAND and flash again. It wrote the whole thing again and then failed at exactly 52K on the check again. I unplugged it turned it on and it was good to go.
I had no problems with the third one but again it failed the check at exactly 52K. Unplugged it and manually booted it with no problem.Last edited by greatestpyro; 27 November 2012, 05:57.
Originally posted by greatestpyro View PostI followed your instructions to the letter. I have three of these tablets that I need to root. Initially I had some issues with the drivers and booting into the flash mode but sorted that out. Got the first tablet in flash mode, erased the NAND, all is good, then on write flash it wrote the entire 535539K then when it went to check the data it failed at 52K. I was unable to do anything so I unplugged it and turned it on. It went to Clockwork and did everything as expected and worked perfectly. It didn't go as planned but it worked correctly and that's all that matters.
Hi, i had the same problem with my computer running windows XP. Before installing service pack 3 everything was fine. After, the loader was acting weird. I had 2 minicube. Sometime i was able to erase the memory and sometimes not (i had to restart the loader). After, sometime i was able to install the ROM but i could never run the "check install".
i've tried with my girlfriend computer (window7) and everything was fine...
I would suggest you to try another computer and/or another usb cable and usb port
There are currently 1532 users online. 1 members and 1531 guests.
