NEW - 900 Supersport 1.1 Jelly Bean rooted ROM for Cube U30GT Mini
The mini does not charge via USB900Supersport
freaktab developer
I hope this new rom will fix my sd card, none of my sd card works in the cube.
I have the 900 supersport 1.1 rom now. I have another bug too, if i charge the cube it will start by itself.
Love your work, ps in my ainol i can flash a file which make it look like a samsung s2 on market and will make a lot of apps work, is it possible to flash this here ?
I have no issues with the sdcard in my mini.
As far as I can see all rk3066 based tablets turn on while charging.900Supersport
freaktab developer
Advantages or ROM Change ?
@ 900supersport
Can you please update the following list of ROM change advantages, as far as I understand !
1 - Improve performances ? (Antutu benchmark score of my original Cube30gtMini is 10997)
2 - Change the welcome Logo ?
3 - Allow all applications to be moved on Sdcard ?
4 - Delete "chinese" games ?
5 - etc
First boot is the first startup.
To format the internal sdcard open settings, storage, mount sdcard, format.900Supersport
freaktab developer
in the bottom of the screen I see
E:Can't mount /cache/recovery/command
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
What should I do ?
Try reflashing, using a different USB port and if you have it a different cable.900Supersport
freaktab developer
That should be fine, are you using one of the USB ports on the rear of the PC?
Do you have another USB cable you could try?
You could try my earlier ROM but this should work.900Supersport
freaktab developer
OK we want USB 2.0, try a different port. Failing that try flashing the standard ROM from cube.900Supersport
freaktab developer
i was do it flashing standard ROM from here http://www.51cube.com/ch/DownShow.asp?ID=117
and it's ok..but i want your ROM
There are currently 3698 users online. 1 members and 3697 guests.
