I'll have to look at that. So what Rom are you on a stock cube or one of mine?
NEW - 900 Supersport 1.1 Jelly Bean rooted ROM for Cube U30GT Mini
Re: NEW - 900 Supersport 1.1 Jelly Bean rooted ROM for Cube U30GT Mini
I'll have to look at that. So what Rom are you on a stock cube or one of mine?900Supersport
freaktab developer
now i got root from here http://forum.xda-developers.com/show....php?t=1987280
and work fine on my cube mini u30gt 4.1 v1.05
Cube Mini CWM error
Just flashed using "ROM Flash Tool" from "cubemini11JB" and I am getting the below errors on reboot:
E:Can't mount /cache/recovery/command
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
The tab had stock v1.04 JB firmware.
Top 1/4 inch of the screen does'nt work???
After I installed the 1.1 jelly bean, the top "Google Search" tool, The microphone Icon and the Applications icon do not work when I touch them. I can turn the tablet and then it works but it seems that the side with the camera does not. My tablet is a Cube U30GT Mini, is there a fix for this issue? Has anyone else had this happen?
Is yours a mini or a mini s?900Supersport
freaktab developer
I'd try re flashing. If that does not cure the issue then try downloading the stock ROM from cubes site and flashing that.
It's possible this is a hardware issue.900Supersport
freaktab developer
I take it that is when flashing the ROM. Try a different USB cable and a different USB port.
Sent from my U30GT 2 using Tapatalk 4900Supersport
freaktab developer
Tablet stuck at ClockworkMod recovery v6.0.1.0
I flashed my Cube mini u30gt and it is now stuck. I have tried several usb cables all my usb ports and it seems I just can't make it happen. This tablet did have jellybean installed on it prior to the flash could this be my problem? I did not check which version it was before I flashed it, Ooops! I think I may have unplugged the usb cable before it rebooted after the flash could that be an issue? Last question is there a way to get it back at this point?
Thanks in advance.
Here is what I see at the bottom of the screen:
E:Can't mount/cache/recovery/last_log
It should be recoverable. Is yours a mini or a mini s?
It's a while since I did this ROM is it clockwork recovery or stock?900Supersport
freaktab developer
There are currently 2532 users online. 1 members and 2531 guests.
