[ROM] Unofficial OpenELEC for MK808B+ and MXQ
New Version works great on my all black MXQ, Fixed WIFI issue, but If I hit the power button on the remote it goes to sleep but no buttons on remote will wake it. No big deal as I don't mind leaving powered at all times or just replugging it if its not being used for a while. Just wanted to chime in, Thanks again for all your hard work.
OK, I've just ordered one of these: http://www.****.co.uk/itm/MXQ-Quad-C...wAAOSwJb9WsBjM
I mean £16!!! With an air-mouse!! That's bonkers! Anyway the proof of the pudding and all that. Might take a while to arrive, probably coming from China, but I'll let you know if it was a bargain. Of course hoping one of K's MXQ builds works on it. ;0)
Originally posted by PatrickJB View PostOK, I've just ordered one of these: http://www.****.co.uk/itm/MXQ-Quad-C...wAAOSwJb9WsBjM
I've just intalled new version 6.0.1.1 and now tvheadend doesn't work. Regarding the logs, I see this message:
# ... output of cat /storage/.kodi/userdata/addon_data/service.multimedia.tvheadend/service.log
# OpenELEC release: Amlogic.HD18Q.arm-6.0.1.1
tvheadend: error while loading shared libraries: libssl.so.27: cannot open shared object file: No such file or directory
In the previous version it was working OK. Any help will be apreciated. Thanks.
Originally posted by mike77 View Post
this one much much better : http://www.****.co.uk/itm/MXQ-Quad-C...4AAOSwv0tVZXAb
I installed this 6.0.1.1 build on my original MK808B Plus and tvheadend server still working as before. HTS Tvheadend 4.0.8 ~ OpenELEC Tvh-addon v6.0.3. I only use my "stick" as a PVR backend.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by md22 View PostI installed 6.0.1.1 build on my MXQ and now every shutdown the mac address change
Video playback using a Samba (SMB) share is very slow (a lot of buffering) on 6.0.1.1 via Ethernet on the MXQ for me.
I tried to use custom cache settings, but buffering is taking forever.
Downloading something via wget on the MXQ and saving it to /dev/null gives me full speed, so Ethernet seems to be fine.
//Edit
When mounting manually, via:
mount -t cifs //192.168.1.1/data /var/media/data/ -o username=freezer,password='xxx'
and adding that location to Videos from Local files, playback is working perfectly. It also uses the new cache settings.
Originally posted by bromilow746745 View Postdoes anyone know or can help me with my control on my box I have installed openelec latest version which is brilliant, I can turn the box off with my remote but cant turn it back on
I have to unplug power cable and than plug back in
Originally posted by JoeyDaPhish View PostNew Version works great on my all black MXQ, Fixed WIFI issue, but If I hit the power button on the remote it goes to sleep but no buttons on remote will wake it. No big deal as I don't mind leaving powered at all times or just replugging it if its not being used for a while. Just wanted to chime in, Thanks again for all your hard work.
There are currently 2086 users online. 0 members and 2086 guests.
