[ROM] Unofficial OpenELEC for MK808B+ and MXQ
kszaq I think I broke my all black MXQ ($50) device :-(
It displays a red light & there the recovery OS is gone tried to use http://chinagadgetsreviews.com/how-t...n-minutes.html but that fails too any idea how to fix it?
(Not blaming you as it's always a risk we take when modifying firmware etc)
I think my main problem is I thought I had to use OpenELEC-Amlogic.HD18Q.arm-5.0.8.19-bootloader.zip on the Recovery Android interface via "apply update from external" which I think broke the device completely & the pin trick does not work anymore.
Originally posted by kszaq View PostGuest Please try using attached remote.conf.
Any update for my mxv,ur new test build have same wifi issue ,shows 2 interface and once reboot box doesn't connect wifi using mxq build.
Using hd18q build still no wifi in setting ?
I put the Dmesg in my previous post .
Awsome, this keymap worked well on your HD18Q build thanks so much... The only thing left would be figuring out why I get WIFI with the MXQ build 5.0.8.19 doing modprobe 8189es. but on the HD18Q 5.0.8.19 there is no wifi? I guess like you said this would be a different kernel tree or something.
Originally posted by Pryxus View PostWow! In the latest release, HDMI-CEC works really well. Finally, my MXQ is about to replace my RPi :-).
Thanks a lot!
Still one question: Is it possible to prevent OpenElec to shut down, even if the Power key of the remote control is pressed?
Thanks a lot!
1. If you use your TV's USB to power the MK808B plus, this problem will solve itself....
2. If you look in your TV's CEC settings you can disable the Power-Saver\CEC settings but leave the rest. This worked on my Panasonic with Viera Link HDMI-CEC implementation.
Thanks- modifying initramfs to load 8723bs and not wifi_dummy module
- insert your own device tree into kernel image
Originally posted by pigbait View PostAwsome, this keymap worked well on your HD18Q build thanks so much... The only thing left would be figuring out why I get WIFI with the MXQ build 5.0.8.19 doing modprobe 8189es. but on the HD18Q 5.0.8.19 there is no wifi? I guess like you said this would be a different kernel tree or something.
Originally posted by kamacnik1 View Posthi guys
has a P2P streams addon work on this ROM on MK808+
I'll try install it but wont work
same addon on windows with same configuration work very well, so I dont think configuration is problem
whats is yours expirience, did somebody try this addon
There are currently 2639 users online. 0 members and 2639 guests.
