[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Do you have a link for that box? I wish they would change the names of the devices, it gets very confusing.
Anyone know where is the file that contains the wifi settings? ( wifi name & password).
I am on the road a lot and take my box with me. I usually have a hard time connecting to a new wifi. Every time I am in a new location and try to connect to a new wifi I click on the wifi name and then click connect.... but nothing happens. I do not get the option to enter password. It just goes back to the list of connections. I have to do many refresh, reboot, wired on/off and more reboots until finally it gives me the option to enter password on new wifi.
Thanks.
When I set Enable Zero Caching in Advancedsettings.xml it isn't writing over the previous cached video, so my flash memory fills up and then videos won't play.
Is anyone else having this issue. I have several other AML boxes that I have enabled zero caching and they write over the previous cached video.
Is it possible to flash a rom via the reboot recovery SSH method?
I can boot to recovery but I will get mount errors with the SDCARD, I have full access to my mk808b+ (apart from flash) but would like a method of flashing android without the need to connect to a PC.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Originally posted by borikua View PostAnyone know where is the file that contains the wifi settings? ( wifi name & password).
Thanks.
Originally posted by Cee604 View PostWhen I set Enable Zero Caching in Advancedsettings.xml it isn't writing over the previous cached video, so my flash memory fills up and then videos won't play.
http://kodi.wiki/view/HOW-TO:Modify_the_video_cache This is what i built mine from. Ill post mine later. This might be the exact one that i use. Example 4 below
I think during my testing i had to change the membuffer size down. I think i did 100 meg.
<advancedsettings>
<network>
<buffermode>1</buffermode>
<cachemembuffersize>157286400</cachemembuffersize>
<readbufferfactor>20</readbufferfactor>
</network>
</advancedsettings>
I realy like this rom and use my MK808B+ in combination with my HTPC and a mysql shared library.
Yesterday I made the mistake of updating kodi to 15.0 on my HTPC which brakes shared library support in my case...
I tried a lot, but I can't seem to roll back the update on my HTPC back to kodi 14.2...
I did however found out that OE 6.0 beta 3 is released with kodi 15.0, so I wonder if it would be possible to release OE beta 3 for the MK808b+ as well?
kszaq Are you sure the 5.95.1 build is equipped with kodi 15? As far as I could find is OE 6.0 beta 3 (5.95.3) the first build that ships kodi 15:
The most visible change is the update from Kodi-14.2 Helix to Kodi-15.0 Isengard (rc 2).
There are currently 4910 users online. 0 members and 4910 guests.
