[ROM] Unofficial OpenELEC for MK808B+ and MXQ
My box doesn't come with any reboot app. I have tried to install some reboot recovery app from the Play Store and I was unable to find any (¿?).
I will try to download one apk with my phone, copy it to the SD and install it in the box from there.
Is there any other way to force a reboot to recovery?
Originally posted by Wendigo View PostMy box doesn't come with any reboot app. I have tried to install some reboot recovery app from the Play Store and I was unable to find any (¿?).
Originally posted by rev6 View Post
Which box?
I have installed Quick Reboot via apk, but it seems that the device is not rooted. Not working.
I didn't want to install p8 to NAND since I would like to keep the original Android ROM installed. I have been unable to find the same stock ROM. Mine is dated 2015/05/18 and newest I have found is several months older.
Originally posted by kszaq View Post
Nobody has given a report on HD18Q yet. You can try issuing a 'reboot recovery' command in Android with the SD card inserted. Your box should reboot, briefly display Recovery Robot and then (hopefully) reboot to OpenELEC.
Originally posted by Wendigo View PostI'm trying to test the SD version in a HD18Q (OTT MXQ), but I'm unable to bring up recovery using the toothpick method.
I own an old GBox Midnight and I'm familiar with the toothpick method, so I'm pretty sure that I'm doing it correctly.
The SD card was prepared restoring the downloaded image using DD, and it is correctly loaded both in the PC and in the MXQ after boot.
I have just received my MXQ and it is the firsts test I do with it, so I don't know if it is a problem of lacking recovery partition or that the SD method simply doesn't work.
Has anyone tried the SD version on the HD18Q?
Originally posted by borikua View Post
there should be an update app in there. That is actually what is called. Update. You can then select zip file you want to flash + select cache & data wipe and it will install it. That is what I have done on some MXQ black boxes. Toothpick on many MXQ black do nothing. Just reboots as usual.
I guess if I can't get to recovery, I can't boot from SD...
Originally posted by borikua View PostTime and Date
I cant properly get time & date. I am using MXQ all black. version p8 & updated to p16.
But both on wireless or Ethernet time & date is wrong with date dec 31, 1969
Tried a adding pool.ntp.org to timeservers but nothing.
Any suggestions?
Thanks.
Hello kszaq ,
Im using the p15 openelec version on mk808b+ and when im watching live tv stream im getting audio noise on sport tv 1 (portuguese channel) and its running on Standart quality. All the others channels audio are working fine. I uploaded 2 short videos on youtube so you could see the difference.
Mk808b+ sound noise:
Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
Pc clear sound (same stream):
Here is my log -> http://xbmclogs.com/ptmtt1b8y
If you can fix this cool, if you cant thanks anyway
Other issues that i spotted:
- Mouse lags wheel/scroll works only when pressed and right click lags alot. Im using mitsai r500 wireless mouse.
- Acestream is not working
- These past 2 days it was booting straight to the videos menu. Today is booting again to the main menu (i know its not stable).
- Kore and yatse are working but very slow when navigating the menus. Does anyone has this problem?Last edited by miguelf; 07-02-2015, 19:14.MK808b Plus @ gearbest
Does that mean "no SD version" for my box, then?
China-1 Stock | Buy High Speed 480Mbps 4 Port USB 2.0 Hub with Individual Power Switches and LEDs online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
I'am thinking of buying this usb hub , plan is to connect on mk808b+ this usb ethernet adapter and Tronsmart air mouse TSM01
China-1 Stock | Buy Tronsmart High Speed USB 2.0 to RJ45 LAN Ethernet Network Adapter for MINI PC TV Box Mac Tablet - White online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
China-1 Stock | Buy Tronsmart TSM01 English Version Air Mouse + Keyboard for TV Box / PC / Motion Sensing Games online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
so question is are this combination work correctly
on mk808+ is last openelec release
Originally posted by kszaq View PostI'll re-check that when I get back home. As a workaround you can rename recovery.img to kernel.img and a toothpick won't be necessary.
Can we open local console with crtl+alt+f3 ? On OE i386 I'd add 'debugging' to kernel boot line to enable local console.
Dear kszaq, many thanks for all your work.
I've an MXQ with red MX and Q button, and everything is fine with stable release on SD.
OpenElec says no BT module avalaible also if my device has BT, but it's not a problem.
I've a slightly unrelated question for you...How different is OpenELEC kernel from an Android Kernel? Is it possible to pack your zImage into a boot.bin for Android?
thanks again!
Any suggestions?
Thanks.
Okay, so after a couple of days of trying to figure this out and doing all kinds of stuff to no avail I finally decided for some reason to connect to my iphone hotspot and realize the time and date started to function correctly. Something in my router? Although same box in Android worked fine. Maybe something to do with MAC address or IP? Don't know. I did a complete hard reset on my router and now time and date is working fine. Whew!
There are currently 2263 users online. 2 members and 2261 guests.
