[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by Mafarricos View Postkszaq
5.0.8-20150623-test2 still gives the same result as previous test version (not working internal), log: http://pastebin.com/3XtXKeYB
Latest working internal wifi is OpenELEC-Amlogic.EC-MK808B.arm-5.0.8-20150511, here's the log of that version: http://pastebin.com/0VXgR1Te
Also I don't know is why I allways see 3 wlans (1 for external dongle and 2 for internal wifi).
Thanks for your test versions, let's see if in the next ones you get what is wrongMaybe I should get a box with Realtek WiFi. Would you mind PMing me a link to where you bought yours?
Originally posted by rev6 View PostWhat's the SSH login the default doesn't seem to work. Want to post logs for x265 on my MXQ. Black screen but audio with latest beta.
BTW: Booting OpenELEC from SD card coming this week.
Originally posted by kszaq View PostActually there is nothing in dmesg that would indicate any issues with WiFi...Maybe I should get a box with Realtek WiFi. Would you mind PMing me a link to where you bought yours?
The login and password are default, you should also enable SSH in OpenELEC settings. If a movie does not work, you should provide a sample as logs won't tell me a thing.
Booting OE from SDcard seems very good! That way we can have android to work with some apps and use Openelec to mediacenter. Will be done with a custom recovery?
I mean can we use a ROM android that works with clone or original, and use openelec, or will be a package of android from emmc and openelec from sdcard?
2 issues with a Sony TV. Both regarding CEC. OpenELEC isn't detecting the TV's remote menu button like the Raspberry Pi did, is there anyway you could fix that or can I somehow?
Another thing is when I switch the box off with the supplied remote, it switches back on automatically.
The first post says about CEC not being configurable but maybe you could fix these 2 things.
Using the latest beta 5.95.1-20150518 on an MXQ
I'll post logs if required and if I knew how
Thanks for your hard work.Last edited by rev6; 24 June 2015, 21:11.
Originally posted by kszaq View PostMafarricos Thank you for the test. Can you try another test build? Link posted below.
ArikZ I may have found a fix (ugly one) for ethernet interface configuration resetting. Please try if it works for you.
http://s805.eu/releases/test/5.0.8-20150623-test1
Thanks' a lot - it works.
ArikZ
Originally posted by rev6 View Post2 issues with a Sony TV. Both regarding CEC. OpenELEC isn't detecting the TV's remote menu button like the Raspberry Pi did, is there anyway you could fix that or can I somehow?
Thanks for your hard work.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
I have bad experience with the HD18Q remote control.
The Arrow Keys and the Select sometimes act as like I have pressed the button twice. It happens a lot and is quite annoying.
It happens with Android as well as with OpenElec, So it is probably not related to this post, but I will be happy to know if this is only my experience or a common issue with HD18Q ?
ArikZ
Originally posted by ArikZ View PostI have bad experience with the HD18Q remote control.
ArikZ
Only another remote is the solution, you should never get this with any Bluetooth one - test the beta however as 15.0 may of done something to resolve this.Currently Using:
Retired Devices:
There are currently 1459 users online. 1 members and 1458 guests.
