I will try to add that option.
[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by Michael BB View PostNo, I can not see it. The option is not available in the OpenElec menu. I have WiFi dongle, I can try to use it, it work normally with the stable version. What can I do?Code:cat /sys/bus/sdio/devices/*/device dmesg | paste
Code:echo modprobe 8723bs > /storage/.config/autostart.sh
Let me know if you need help in connecting over SSH.
Thank you in advance for your help! And sorry for the inconvencies you are experiencing but I don't have a 8723BS device and I can't test the releases.I hope this can be resolved soon.
The result is attached to the post. The Bluetooth doesn't work.
EDIT: After I detach the WiFI stick, the connection is visible, but it can not connects. It shows association and after few seconds - failure. Same like in test version 2. If the stick is on, connects normally.Attached FilesLast edited by Michael BB; 09 June 2015, 22:21.
Michael BB From your dmesg it looks like the WiFi chip is detected but the driver is not automatically loaded. Please try this build: (deleted, use 5.0.8p15)
I added an udev rule to load the driver when the WiFi chip is detected.Last edited by kszaq; 09 June 2015, 23:27.
Michael BB And I thank you for your patience and testing.I understand that Bluetooth is also working?
I have instaled the latest https://github.com/kszaq/OpenELEC.tv...s/tag/5.0.8p15 on my MXQ HD18Q black box.
The MAC address of the Wifi card is stable after reboot as promised, but the LAN card MAC address changes on every reboot.
Thank you. I think the reason why the Bluetooth doesn't work might be that the driver was compiled for Bluedroid and not BlueZ that is used in OpenELEC. I will change that for next builds and we'll see if that helps.
Originally posted by envagyok View PostNo HD audio, nor bitstream, nor decode to pcm mode
Originally posted by ArikZ View PostI have instaled the latest https://github.com/kszaq/OpenELEC.tv...s/tag/5.0.8p15 on my MXQ HD18Q black box.
Originally posted by kszaq View PostThank you. I think the reason why the Bluetooth doesn't work might be that the driver was compiled for Bluedroid and not BlueZ that is used in OpenELEC. I will change that for next builds and we'll see if that helps.
Thank you for checking that.
I don't have a HD18Q so I need at least a dmesg from you collected right after booting the box. Can you also chceck whether the MAC address changes if you install MXQ build on your box?Attached Files
There are currently 2067 users online. 0 members and 2067 guests.
