[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by csgabe View Post
Originally posted by envagyok View PostHi,
mxq original with 5.95.1 original remote not working
Cec ok
Problems with wired ethernet too.
envagyok I have found a reason why the factory remote may have not worked - this was due to changes in amremote package. I have compiled an updated version, please try it: 5.95.1-20150515.
Originally posted by kszaq View PostIf you want me to help you have to provide meaningful logs. Tell me if you did a clean install or an upgrade. And please also describe "problems with wired ethernet".
You should know that T230 tuner support is experimental and may not work as it hasn't been tested by me.
I will also need to setup a web server as a single release in now almost 1GB having 4 devices.
Originally posted by csgabe View PostYou are right. I've tested it: the tuner works, but streams are unwatchable, because video and audio breaks up(also some part of video is green).
If you are Polish, az.pl has a nice offer, 15 zloty for a year of hosting(Hosting Start: 50GB space ) :
https://www.az.pl/hosting/#oferta
I also have compiled a test TV110 firmware for you - I took dtb from factory image. Please test if it fixes issues you are experiencing: http://s805.eu/releases/5.0.8-20150511/test/
Originally posted by cesarpt View Postkszaq the problem with the tuner may not be a problem with drivers, I've tryed to stream from my wetek and on my other devices I've never had problems, in my mk808b plus it just doesn't stream, can it be the player used in live tv ?
Originally posted by kszaq View Postenvagyok I have found a reason why the factory remote may have not worked - this was due to changes in amremote package. I have compiled an updated version, please try it: 5.95.1-20150515.
Thanks, now working everything...
The network problem I think never existed I think it was bad plug error.
Tested TV110 version, sound still didn't work(maybe it's because my box doesn't recognize edid of TV ), but this autostart.sh script fixed that( only had to change to 720p then back to 1080p) .
echo 720p > /sys/class/display/mode
echo 1080p > /sys/class/display/mode
SUBSYSTEM=="net", KERNEL=="eth0", RUN+="/sbin/ip link set dev %k address XX:XX:XX:XX:XX:XX"
I had to change dvfs table in the device tree file, because my box needs higher voltages(probably have older board which required higher voltages) or otherwise it would freeze:
Code:dvfs_table = < /* NOTE: frequent in this table must be ascending order */ 96000 1020000 1020000 192000 1020000 1020000 312000 1020000 1020000 408000 1020000 1020000 504000 1020000 1020000 600000 1020000 1020000 720000 1020000 1020000 816000 1020000 1020000 1008000 1140000 1140000 1200000 1140000 1140000 1320000 1140000 1140000 1488000 1140000 1140000 1536000 1140000 1140000 >;
Thanks for building for TV110 too.
And the remote(my box came with a white remote) didn't work properly, but copying this remote.conf(I modified it a little bit) to /storage/.config fixed it:
https://my.powerfolder.com/dl/fiQ1vY...p6/remote.conf
Wifi doesn't show on network(openelec configuration), here is the dmesg:
TV110 wifi chip is AP6210.Last edited by csgabe; 16 May 2015, 11:55.
cesarpt I think you may be correct that the problem with DVB-T tuners may not be in DVB drivers. I have tested my IT9135 tuner today and got the same results. I have read somewhere that the problem may be in USB drivers. I'll try to look at it but can't promise anything.
csgabe can you provide me a link to a working Android firmware, preferably in USB Burning Tool format? I used the one you posted some time ago from http://chinagadgetsreviews.blogspot.ro and maybe parameters extracted from it are wrong.
This was the last version:
https://mega.co.nz/#!xQhiXTaB!llJAOs...-3MkaciTmaMt10
You probably know, but if you don't you can use the CustomizationTool from Amlogic to unpack this firmware.
Wifi worked with Beelink MXQ version of OpenElec.
Guys, I ordered a mxq, the box on the site where I ordered satys OTT on it and the brand is Vensmile or Vsmart. Is this a HD18Q mxq? Will this firmware work with it? It looks like the em6q-mxq however the remote is newer one, more slimmer. Are these good boxes? I'm planning on ordering more as the price is really good, only 40 bucks u.s. Does anyone know if this new version has a heatsink on the cpu like the em6q-mxq? I know the beelink version of mxq s85 doesn't have a heatsink but a thick foil type paper.
kszaq,
I just installed your 5.08 on my MXQ and working nicely. Only problem if I switch on hardware acceleration and pay a file, any file, one part of the screen turns to Openelec screen with garbage. Here is the picture how it looks like. If I switch off hardware acceleration, everything OK, but of course in this case 720p x265 does not play properly. Otherwise everything looks OK, Dolby Digital sound works through HDMI cable too.
I tried to switch the video resolution, it does not help. My TV is a 2008 Panasonic plasma with 1280x720p resolution.
Any idea what is wrong?
Thanks,
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 4249 users online. 0 members and 4249 guests.
