[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Kszaq, I have been using your port of OpenELEC for a month or two now as a stand alone PVR/DVR, and it is working fantastic. To show you my appreciation, I sent you a couple of beers. Enjoy
Originally posted by MeleTest View Post
Ok. I have flashed this version and network is back
Originally posted by clarkss12 View PostKszaq, I have been using your port of OpenELEC for a month or two now as a stand alone PVR/DVR, and it is working fantastic. To show you my appreciation, I sent you a couple of beers. Enjoy
Originally posted by kszaqThat would mean having to prepare OpenELEC 4.2.1 and it will take time as I've never worked on it before, it needs to be prepared (almost) from the scratch. You should also be aware that there is no support for HEVC in 13.2/4.2.1.
hey kszaq I love your roms. been using them since they were posted here. I have a question for you though, is there any chance that you can update the librtmp files in the rom to the latest from redpenguin I think its the 3-16-15. I see the instuctions for openelec on rasp pi but dunno which files we would use for the MK808B Plus as its not a Pi.
dunno if I can link here but if I cant mods please edit the link out.
Last edited by kashmoney; 21 April 2015, 20:11. Reason: http://forums.tvaddons.ag/threads/10213-How-to-use-lastest-librtmp-with-openELEC
Originally posted by kashmoney View Posthey kszaq I love your roms. been using them since they were posted here. I have a question for you though, is there any chance that you can update the librtmp files in the rom to the latest from redpenguin I think its the 3-16-15. I see the instuctions for openelec on rasp pi but dunno which files we would use for the MK808B Plus as its not a Pi.
http://forums.tvaddons.ag/threads/10...-with-openELEC
Hi kszaq,
Still have the long boot time on the all black MXQ using https://github.com/kszaq/OpenELEC.tv...es/tag/5.0.8p4 Also there is no ethernet port.
Originally posted by jackmate View Postget the pics as attached even when not playing video and unit just in not use .
To me looks like Dubug enabled In this test build ,can u help Pls .
Hello everyone,
I recently purchased MK808B+ and now openELEC runs on the player. OpenELEC is latest test release (5.0.8-20150421) Everything works perfectly, fast boot and all, but I have a few questions?
I noticed slightly audio delay on my TV after seeking through video (FF,FR) in Kodi. This was not the issue with Kodi on Android at the beginning?
Is there a way (except CEC functionality.) to get player running from the Off state. In fact, although the TV that is connected supports CEC (Sony KDLW4000) I could not manage to control the MK808+ via TV remote (it shows some CEC controled device in GUI of the TV). At the other Samsung TV it appears that the CEC works. For now I use android application Yatse to control Kodi interface. I can shut down Kodi, but only way to boot up is to reconnect USB power cable.
Once again congratulations to developers at an extraordinary work.
Greeting
Originally posted by kszaqThe all-black MXQ is a bit different in hardware and I suppose it needs a separate build. I will try to make a test build for you today evening (CEST).
As far as I remember, another user fixed that by flashing the latest Android firmware using USB Burning Tool (you can find it here: http://androidpc.es/blog/2015/04/10/...-con-soc-s805/) and flashing back OpenELEC. I have experienced this issue on my MK808B+ but only when it was underpowered, which should not be the case with MXQ since it uses a separate power adapter.
This build from April 21 has this issue in same box .
I am using https://github.com/kszaq/OpenELEC.tv...es/tag/5.0.8p4Last edited by jackmate; 23 April 2015, 11:53.
Originally posted by kszaq View PostThe problem with ethernet is very odd since there were no changes in ethernet support/drivers. I have recompiled the 5.0.8p3 from the scratch and posted it as 5.0.8p4: https://github.com/kszaq/OpenELEC.tv...es/tag/5.0.8p4 Would you be so kind and test it on your MXQ? I don't have one (yet).
Thank you! I appreciate your support!
This version has the same problem : no ethernet and wifi can't connect.
I would really like to install this build to my MXQ that I´m planning to give to my older relative for media box. However, it would be really nice that multichannel audio out and bitstreaming would work. Is there any possibility to get them working in the near future? I´ve got an AVR and I can do some testing if that´s any help.
Greeting
Hello Kszaq,
Originally posted by juukeli View PostI would really like to install this build to my MXQ that I´m planning to give to my older relative for media box. However, it would be really nice that multichannel audio out and bitstreaming would work. Is there any possibility to get them working in the near future? I´ve got an AVR and I can do some testing if that´s any help.
@ MXQ users: I am sorry for the issues you are experiencing with the latest test builds. I don't have a MXQ and I can't test them but here's some good news: thanks to generous donations from noosk and clarkss12 I ordered a Beelink MXQ and it should arrive in ca. 3 weeks time. That means better support for you!
Here is another test build for MXQ users: I excluded the drivers for Realtek 8723AS and BS (there seems to be no MXQ that uses this) and used the latest eMMC driver. People with issues, please test this. Also remember to write which MXQ you have: Beelink or EM6Q-MXQ (aka HD18Q).
There are currently 3864 users online. 0 members and 3864 guests.
