[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by pajopasa View Post). Considering your observations I decided to make ondemand the default governor for my next releases. Thanks for your input!
Originally posted by envagyok View PostHi kszaq,
Unfortunately at 5.0.8 i cannot reach the tvheadend server port at 9981 for web configuring.
Before at 5.0.7. it worked, Aftern.0.8. i try reinstall, delete, disable, enable the tvheadend server addon without succes.
Then i revert to 5.0.7., and worked again the web interface.
Can you provide a log?
Originally posted by kszaqYou can probably fix this by flashing a bootloader meant for your device. Here's how to do it:- Download a zip release from GitHub page.
- Unpack it to a SD card.
- Delete factory_update_param.aml and recovery.img files.
- Grab a bootloader.img from your Android firmware and put it into the OpenELEC-Amlogic.MXQ.arm-5.0.x-update.zip file (overwrite existing bootloader.img).
- Download TWRP recovery and copy it to your SD card. Rename it to recovery.img.
- Boot using a toothpick and flash your modified zip. Do not "root" the firmware.
It should boot much faster unless there are file system check operations being performed for some reason. Did previous builds work for you?
It's more than 2 minutes now to start into KODI . Another issue is openelec setting has left text missing like in pics ,using confluence custom skin.
@jackmate
Is yours the all black model with the MXQ logo on the top? I have the long boot up time with this model but once you swap the bootloader you can just put the unit into standby and it will wake up in seconds. I don't have the missing text problem. Does this just happen on your custom skin? I use Aeon Nox without any problems.
Which bootloader do I swap in the firmware ,I would like to try that Pls.
Missing text is on confluence custom skin ,in default confluence skin it's fine .
Originally posted by jackmate View Post
No ,I got Mxq with buttom on top
Originally posted by kszaq View PostYour box looks like Beelink MXQ but it might be yet another clone... can you post a dmesg here so that we may see if something wrong is going on?
the kodi shows in screen almost after 4-5 minutes.openelec splash screen appears during this time.
The seller tells me its orignial beelink mxq.
http://sprunge.us/AVXgCode:[COLOR=#000000][0m[aml_sdio_timeout][0;40;33m emmc: cmd0, ISR have been run, xfer_step=2, time_start_cnt=499mS, timeout_cnt=2[/COLOR]
Can you try flashing factory image via USB Burning Tool (use 107k4, as previously requested) and see if the problem persists with Android?
I have the same problem as you : kodi HTS client can't rich thveadend server. In my case, sure this have relation with my USB TNT dongle, because when I take it off and reboot, evereything goes right as with the 5.0.7.
Here follows the dmesg log file relative to this part:
Originally posted by kszaqThere are a lot of messages like this one:Code:[COLOR=#000000][0m[aml_sdio_timeout][0;40;33m emmc: cmd0, ISR have been run, xfer_step=2, time_start_cnt=499mS, timeout_cnt=2[/COLOR]
And works fine as expected .boots android in 20 seconds .
It's only when I flash openelec ,takes 4 min to bring KODI on screen .
http://www.mediafire.com/download/wb...0_20141231.rar (password: geekbuying.com)
I bought this device for purely using ur openelec build ,not interested in slow android .
What option do I have to boot kodi faster in this ,it's takes 4-5 min to bring kodi on screen right now .
Originally posted by MeleTest View Post
Hi envagyok,
The seller tells me it's beelink box ,beelink recently started changed flash to Emmc instead of nand flash .
Originally posted by kszaqIt seems like this patch: https://github.com/kszaq/OpenELEC.tv...d1b3827d1e7831 broke media_build drivers. I would need to find a way to make it work for both you using DVB tuners and people needing a working LIRC. I will revert this patch in the next release
Have you tried flashing back OpenELEC after flashing Android?
There are currently 3987 users online. 0 members and 3987 guests.
