[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Just for information, I am running version 5.0.3, and from clicking the reboot, and Kodi is ready to use is 29 seconds. I have the MK808B+ from Geekbuying, and have a USB Gigabit Ethernet adapter connected to the main USB port. I have a wireless mouse attached to the OTG port using the included micro USB to USB cable. I am using a mini HDMI to standard HDMI adapter for my connection to my Denon A/V receiver. I am running the tvheadend server with 2 networked HDHomerun tuners, and my pause buffer is ported to my class 10, 32gig micro SD card. My recordings are ported to my Synology NAS. I do not have a lot of addons, but all my media is stored on my NAS. I am also using the stock power supply that came with this stick.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by kszaq View PostIs it 4-5 minutes on every boot or only on the first one? Can you post a dmesg without pressing any remote buttons as they are logged in dmesg and I can't read the very fists lines from it?
its always 4-5 min to boot kodi,here is dmesg again without any remote press.
For the time being you can either keep your box on (my MK808B+ consumes less than 3W when idle) or you can power it off over CEC/via Kodi menu - that puts the box to sleep and it should wake almost instantly.
Originally posted by johnpushon View PostThank you very much for doing all this job!
I am very appreciating that!
Hope this wont be discontinued anytime soon
Originally posted by kszaqIt looks like a problem with emmc driver. I will compile a test version for you with a different driver but you need to wait a bit for it, I need to find some spare time to do it.For the time being you can either keep your box on (my MK808B+ consumes less than 3W when idle) or you can power it off over CEC/via Kodi menu - that puts the box to sleep and it should wake almost instantly.
I use the MK808B+ to watch movies several times a week and since this ROM is my daily driver I have no plans to discontinue it.
Should I flash mk808b openelc build in my mxq and problem will be solved and it should boot fAster?
Thanks for ur help mate ,will wait for ur test build .
I have the same problem with the 4-5 min loading time. I bought my first MXQ in january, that one works perfectly, bought a second unit from same seller, same item, and this unit has the loading problem.
MXQ with red markings and power button on top.Last edited by ecko404; 18 April 2015, 13:04.
Hello, I need help I have a mk808b I installed OpenELEC-Amlogic.MK808B.Plus.arm-5.0.8-20150409.zip addition, the problem is that I can not turn on wifi as openelec menu settings do not have this option !! !
The mainboard is marked as EC_MK808B
I am attaching some pictures to be more clear.
So where do I enable wifi?
please help me!
Originally posted by kszaq View PostIt looks like a problem with emmc driver. I will compile a test version for you with a different driver but you need to wait a bit for it, I need to find some spare time to do it.For the time being you can either keep your box on (my MK808B+ consumes less than 3W when idle) or you can power it off over CEC/via Kodi menu - that puts the box to sleep and it should wake almost instantly.
Originally posted by krystyan View PostHello, I need help I have a mk808b I installed OpenELEC-Amlogic.MK808B.Plus.arm-5.0.8-20150409.zip addition, the problem is that I can not turn on wifi as openelec menu settings do not have this option !! !
[ATTACH]n494669[/ATTACH] [ATTACH]n494670[/ATTACH] [ATTACH]n494671[/ATTACH] [ATTACH]n494672[/ATTACH]
please help me!
EDIT: After some research i found out that the EC MK808B comes with RTL8723bs WIFI. It is a different device than the MK808B plus, but maybe kszaq can add support for it too.
Hi to all
first thanks to kszag and codesnake for doing a great job
secondly - krystyan - i thing you are searching on wrong place
when you get on main screen to system , in drop menu beneath you have openelec column ( along with file manager , system info , profiles ... )
you must enter inside openELEC and there in network enable wireles connections
sorry for my english
There are currently 4938 users online. 0 members and 4938 guests.
