cesarpt, please try the release linked above and the TVHeadend I attached to this post. I can't guarantee your tuner will work, though.
[ROM] Unofficial OpenELEC for MK808B+ and MXQ
jackmate, thank you for your tests. I've released a new version that is exactly like the one I uploaded to box.com earlier: https://github.com/kszaq/OpenELEC.tv...es/tag/5.0.8p7
Firstly, thanks for the effort being put into this kszaq, much appreciated. Quick note on the jackmate version, on my Beelink MXQ, when first loaded SSH is disabled. Trouble is, when I enable SSH and reboot, my mac address changes (and every reboot after that) and I pick up a new DHCP address, not a big deal as I can set a static. Just caused some confusion when my Kodi remote app kept not finding the MXQ. If I uncheck SSH, the mac stays static, very strange.Last edited by atcusb; 01 May 2015, 21:37.
Hi kszaq,
I've just flashed the latest version for the HD18Q and it's still working fine. Now that you have separate versions for the different MXQ's I was wondering if you could include the HD18Q remote.conf into the build. I also have a recovery.img which works with this remote and a bootloader.img which allows the unit to be powered off and on properly. I've included all of the files in the zip.
Thanks again.
Thanks again.
Originally posted by johnnyc15 View PostWhere can I download openelec for the all black mxq please as the git hub link not
working
Download the HD18Q version.
Originally posted by atcusb View PostFirstly, thanks for the effort being put into this kszaq, much appreciated. Quick note on the jackmate version, on my Beelink MXQ, when first loaded SSH is disabled. Trouble is, when I enable SSH and reboot, my mac address changes (and every reboot after that) and I pick up a new DHCP address, not a big deal as I can set a static. Just caused some confusion when my Kodi remote app kept not finding the MXQ. If I uncheck SSH, the mac stays static, very strange.
Thanks again.
Can you please upload a photo of your remote?
Originally posted by mpp View Post
MK808B+: this ROM is made for this device and this is the only one that I have. There is also a version for Realtek 8723BS WiFi clones.
MXQ: works unless it's a clone.
Originally posted by kszaq View Post
Will do that for the next build. But doesn't the all-black MXQ come with the same remote as Beelink MXQ? Look here: http://www.geekbuying.com/item/H-MXQ...ck-339500.html
This is the remote that comes with the all-black MXQ:
It looks similar to the beelink one but it is definitely not the same. It has a couple of learning ir programmable buttons toward the top of the remote for tv control. I also have to put the remote.conf in the config folder for it to work.
remote.conf
There are currently 4051 users online. 0 members and 4051 guests.
