I have to disconnect hdmi cable while I am not using the device
[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by envagyok View PostKszaq, can you help me how can i patch the kernel?
The otheqr dvb-t stick (1f4d:d803) it is supported since kernel 3.6 but have other HW id as others. It is rtl2832u, but come from a hungarian vendor called alcor..
I read articles about it, but im not skilled with Linux.
http://www.dfragos.me/2012/11/installation-of-rtl2832u-chip-based-dvb-t-usb-stick.html
I can patch the kernel via ssh? Or how can i manually added this usb stick hw vendor and id number to kernel?
If your stick is still not recognized after this update, make sure that the appropriate kernel modules are loaded.
Originally posted by kszaq View PostYou need to recompile the kernel to patch it or at least recompile the modules. With OpenELEC, the easiest way is to download the source and compile it with patches but it takes some time if you do this for the first time. I built a test image for you with the patches you requested:
Very Big Thanks!!!!
Working the stick already!!!
Can this patch stay for future releases? In central Europe many people use this stick.
Thank You Again!
This kernel working with wetek play too?
Thank You Again!
The kernel binary won't work with WeTek Play but I will push the patch to my GitHub soon and make a pull request to Codesnake's repo. If he chooses to accept it, your stick will work with WeTek Play as well.
Can you check whether your other stick - the PCTV/Pinnacle one - works after this update?
Originally posted by kszaq View PostI will keep the patch in future releases since it is needed by you and does no harm to others.
I controlled better now, and there is a problem.
With new soft overall has mxw no audio output at hdmi. No audionat movies, music, etc.
At settings panel diappeared audio passtrough settings,
Thanks for the pushing to GitHub, please keep me informed about codesnake accept or not the patch..
Thanks Again...
#edited
With watching dvb-t channels sometimes catch the playback with both tuner.
Audio still missing over hdmi, I try restart, etc.Last edited by envagyok; 22 March 2015, 16:43.
Guys, what temperature (check over SSH via "cat /sys/devices/virtual/hwmon/hwmon0/temp1_input" ) are you observing on your MK808B+ while running OpenELEC? I'm getting 66-69 °C while idle (using ondemand governor), have not even added my samba shares to XBMC, OpenELEC/XBMC currently just shares 1 USB flash via samba.
On Android it was 50-55 while idle, around 63 when playing HD video over LAN.
Originally posted by envagyok View PostWhen HDMI cable wrong, then why working cec with 5.0.5. 09-03-2015?
I have wetek player too. With 5.0.6 is working, but cec name is missing.
Maybe remove from cec config one real name or something changed with configuration.
I twice make a probe :
5.0.5. 09-03-15 cec working
5.0.6. Tar update cec isnt work.
5.0.5 09-03-15 downgrade cec working again
Clean install 5.0.6 cec isnt work
Ckean install 5.0.5 08-03-15 cec working agsin
Originally posted by kszaq View PostThis is very odd. I will make a clean compile for the next release to prevent residue from my test builds breaking things. For the time being, if you want to use 5.0.6 you may copy KERNEL and KERNEL.md5 from 5.0.5 release and SYSTEM plus SYSTEM.md5 from 5.0.6 release to the Update folder.Last edited by mike77; 22 March 2015, 18:17.
@envagyok, @mike77: Sorry for the non-working audio, this is a result of my trials with HD-Audio (unfortunately I haven't had any success with it yet). Here's an updated build, the audio should work again: https://app.box.com/s/u4zeo847ht9d5w3leptc6gllebrt0hqz
I have also made a pull request to Codesnake's repo: https://github.com/codesnake/OpenELEC.tv/pull/54
Originally posted by GreenAir View Postthank you for all your work kszaq
i already set up 3 MK808B PLUS for my friends and more are on the way
is it possible to include an overclockable kernel like in cyanogen roms?
it's "fast enough" for everyday use but scraping/updating a big library could always use some speed boost
Originally posted by shamanNS View PostGuys, what temperature (check over SSH via "cat /sys/devices/virtual/hwmon/hwmon0/temp1_input" ) are you observing on your MK808B+ while running OpenELEC? I'm getting 66-69 °C while idle (using ondemand governor), have not even added my samba shares to XBMC, OpenELEC/XBMC currently just shares 1 USB flash via samba.
On Android it was 50-55 while idle, around 63 when playing HD video over LAN.Last edited by kszaq; 22 March 2015, 21:28.
Originally posted by kszaq View Post@envagyok, @mike77: Sorry for the non-working audio, this is a result of my trials with HD-Audio (unfortunately I haven't had any success with it yet). Here's an updated build, the audio should work again: https://app.box.com/s/u4zeo847ht9d5w3leptc6gllebrt0hqz
I noticed only that: every 11-12 sec the TV stream freezes for 0.5sec while audio stays continous.
Thanks again!
Since I don't own an AV receiver I would like to get some feedback from you on an experimental change I made to audio settings.
- Download the experimental release (it shouldn't break anything but you can always revert to previous release without wiping your data): https://github.com/kszaq/OpenELEC.tv.../5.0.6-hd-test
- In audio settings, change both your audio output device and passthrough device to HDMI.
- Please report if the following work (considering you have an audio setup to handle it):
- multichannel PCM audio
- TrueHD passthrough
- DTS-HD MA passthrough
- MXQ users: S/PDIF passthrough
- Please also report regressions in audio if you noticed any.
Thanks in advance for the reports!
Originally posted by kszaq View PostSince I don't own an AV receiver I would like to get some feedback from you on an experimental change I made to audio settings.
I set up audio device to hdmi, passtrough device grayed out to hdmi (i didnt use optical), set up speaker config to 5.1
I set up first every hd sound to passtrough.
Then truehd and dts-hd isnt has sound, my receiver displayed unknown source.
The i disable hd audio passtrough, then dts-hd played normal is played downconverted to normal multichannel dts, and dolby hd converted to 2.0pcm 48khz, no multichannel.
I try multichannel audio source too, what is downconverted to 2.0 pcm 48khz..
Thanks Kszaq, this is one step to solution. Dolby hd software decoding to 2.0 already working..
My mxq with every update always better a little.
Thanks again...
Hello,
You image is the best for the Beelink MXQ, but several mpeg2 files are stuttering.
This is an example: https://samples.libav.org/MPEG2/interlaced/burosch1.mpg
Please fix this, if possible.
Many thanks!
Many thanks!
I try with rpi2 and openelec 5.0.6 too, there is no stuttering, but with wetek and mxq stutter the video.Last edited by envagyok; 24 March 2015, 13:22.
There are currently 2910 users online. 1 members and 2909 guests.
