[ROM] Unofficial OpenELEC for MK808B+ and MXQ
    First of all, thanks for the Openelec port to MK808B Plus!
    I have tried, IT9135 DVB-T is successfully initialized, so, drivers seems OK.
    Unfortunately in my OpenElec the tvheadend addon is missing.. In the latest version, too. Any idea?
    I have tried to install several versions from zip, but the web interface isn't working..
      In this minute I have found the zip version of the tvheadend.. Web interface is working, I hope it will be good..
        Originally posted by sultanapex View Post
        How could i update my MXQ? I have installed from github with latest release (5.0.3-20150214). I have installed addons and services. Is there any update method without reset my box?
        Please read the OP, there is an information on how to update.
        TVHeadend has been moved to unofficial addons and you can download it from there.
          cant boot to recovery need help
          I've installed this OpenElec on BeeLink MXQ and works great.
          I want to go back to android but i can't boot into recovery..
          Toothpick metod doesn't work anymore.. just boots normally to Kodi
          Is there a way to flash boot/recovery from ssh using stock rom .img/zip files..
          (i want android back cuz there X11 server/sdl app works..
          since i dont know how to make x11 working on OpenElec)
            Try typing reboot recovery in SSH shell. Toothpick method should work nonetheless. If nothing of this works, you can flash an image using USB Burning Tool.
              'reboot recovery' doesnt work boots kodi..
              Usb burning tool 2.0.3 .. doesnt detect it
              Is there a way i can flash bootloader/recovery from ssh..
              (I need that x11 or wayland :/ i saw hardkernel guys made x11/wayland make it work on similiar spec c1/s805-mali450..but i have no skills with framebuffer,compiling x11/egl with mali.drivers etc..just want android back running x11 srv..im gonna start2cry im so desperated right now)
                Yes, there is dd. But I soft-bricked my MK808B+ using it so I don't recommend it unless nothing else works.
                Regarding toothpick method: do you a have a SD card with update (including factory_update_param.aml) inserted when you try it?
                Regarding USB Burning Tool: I successfully used it after connecting my device to the PC via an OTG port ONLY - no power adapter! Also make sure you have installed the drivers.
                Don't cry and keep trying, there's always a way!
                  Good words really, from a very complete person, kudos @kszaq!
                  Inviato dal mio Nexus 5 utilizzando Tapatalk
                    Code:
                     I have OpenELEC-Amlogic.MXQ.arm-5.0.3-20150226-test-2.tar installed
                    parted -l
                    Model: Unknown (unknown)
                    Disk /dev/boot: 33.6MB
                    Sector size (logical/physical): 512B/262144B
                    Partition Table: unknown
                    Disk Flags:
                    Disk /dev/data: 5910MB
                    Partition Table: loop
                    Disk Flags:
                    Number  Start  End     Size    File system  Flags
                     1      0.00B  5910MB  5910MB  ext4
                    Disk /dev/logo: 33.6MB
                    Disk Flags:
                    Disk /dev/misc: 33.6MB
                    Disk Flags:
                    Disk /dev/cache: 537MB
                    Disk Flags:
                     1      0.00B  537MB  537MB  ext4
                    Model: SD SD16G (sd/mmc)
                    Disk /dev/mmcblk0: 15.8GB
                    Sector size (logical/physical): 512B/512B
                    Partition Table: msdos
                    Disk Flags:
                    Number  Start   End     Size    Type     File system  Flags
                     1      4194kB  15.8GB  15.8GB  primary  fat32        lba
                    Disk /dev/system: 1074MB
                    Disk Flags:
                     1      0.00B  1074MB  1074MB  ext4
                    Disk /dev/recovery: 33.6MB
                    Disk Flags:
                    ___ uname -a;df -h
                    Linux Oe 3.10.61 #1 SMP Thu Feb 26 23:23:23 CET 2015 armv7l GNU/Linux
                    Filesystem                Size      Used Available Use% Mounted on
                    devtmpfs                404.0M         0    404.0M   0% /dev
                    /dev/system             991.9M     97.9M    878.0M  10% /flash
                    /dev/data                 5.3G      4.2G      1.1G  79% /storage
                    /dev/loop0               96.8M     96.8M         0 100% /
                    tmpfs                   405.7M         0    405.7M   0% /dev/shm
                    tmpfs                   405.7M      4.6M    401.1M   1% /run
                    tmpfs                   405.7M         0    405.7M   0% /sys/fs/cgroup
                    tmpfs                   405.7M      4.0K    405.7M   0% /tmp
                    tmpfs                   405.7M     28.0K    405.7M   0% /var
                    /dev/mmcblk0p1           14.7G      1.4G     13.4G   9% /var/media/mmcblk0p1-mmc-SD16G_0x62a19c9d
                    can u upload .img files like boot,recovery etc for mxq that i can dd'it directly from ssh pls.. would make me stop cryin ..whats your pp address i can donate couple beers for your time
                      FYI.. I have installed tvheadend server to MK808B Plus and plugged an IT9135 DVB-T stick in. Everything is working, I can view the TV channels on my PC/Windows, but sadly, the MK808B wifi isn't enough for smooth streaming. (router and the stick is in different room, about 6 meters)
                      I have to buy an USB Ethernet adapter and test again. But, the software/Openelec part is 100%.
                      Thanks again!
                        You can find recovery.img in the archive with your ROM which can be downloaded here: http://www.freaktab.com/showthread.php?18584
                        Are you sure that unpacking it onto sdcard and using toothpick doesn't work?
                        If not, you may try flashing recovery from the command line by typing dd if=recovery.img of=/dev/recovery bs=512 but this does not work on my MK808B Plus!
                          Everyone to their own I guess but for me once I flashed the 808B+ with OpenELEC there was no going back to Android. OpenELEC compared to Android Kodi is to me a different world.
                            Btw.. Which devices should I use in OTG and which in normal USB port..?
                            Tuner, wifi, mouse, keyboard, HDD..?
                            Thanks!
                              Hi Kszaq,
                              I didn't see any question about this, but do you think that is possible to use MK808BPLUS with a USB DVB Tuner, like HTC Terratec HD (features a empia 288xx chipset), with TVHEADEND, with your Openelec port?
                                Originally posted by tsfamd View Post
                                Hi Kszaq,
                                USB IT9135 DVB-T is working with tvheadend, so, if openelec basically support empia 288xx chipset, that will working too.
