[ROM] Unofficial OpenELEC for MK808B+ and MXQ
[ROM] Unofficial OpenELEC 5.0.3 for MK808B Plus and Beelink MXQ
Originally posted by freezer2k View Post
Originally posted by freezer2k View PostThe automatic framerate switching seems to work as well,
but for a 23.976fps movie it will go for 24.00hz, which results in some lag periodically.
So 23.976hz is not yet supported? I know my Sony TV supports it.Originally posted by Iso-playback View PostAt the beginning of this project I asked codesnake if 23.976 & 59.94 could be added to resolve lag and his response was something like being fixed in a later release but you won't see 23.976 just 24 but it will be working.
Edit: Please download an update and test: https://github.com/kszaq/OpenELEC.tv...es/tag/5.0.3p2
Originally posted by freezer2k View PostToday I also got an external USB hard-drive, at first it was not detected at all, but after rebooting it was all fine.
Looks like (this) usb drive(s) are only detected if they are plugged in during boot time -- any idea why this is?Last edited by kszaq; 14 February 2015, 12:51.
Originally posted by kszaq View Post23.976Hz and 59.94Hz modes are supported and you can confirm that by issuing cat /sys/class/display/mode while playing a 23.976/59.94Hz video. It seems like there is a problem with video/screen sync. I think I may have found the reason and I'll make changes and do some tests today or tomorrow. For now if you choose not to turn automatic framerate switching on, you'll get 59.94Hz for 23.976fps videos which should be better-looking than 23.976Hz with periodic stuttering.
It hasn't happened to me. Can you grab a kernel log (dmesg or cat /proc/kmsg) when this happens?
Thanks, will test the update.
Well, that's the weird thing, there's _nothing_ in dmesg when I plug it in.
Not even USB device connected or anything, also can't see the device in lsusb.
When i then type 'reboot' the drive will already blink in u-boot and then also show up in OpenELEC...
//Update
Applied the 20150214.tar ; looks like 24p is good nowDid not notice lag so far.
OpenELEC:~ # cat /sys/class/display/mode
1080p23hzLast edited by freezer2k; 14 February 2015, 19:42.
Originally posted by freezer2k View PostJust flashed the 5.0.3 release on my MXQ, seems to work well so far!
Thanks a lot for all your work kszaq!
1080p23Hz
No problems with my usb drives, always detected.
I will try new update.
EDIT:
@freezer2k , you had right!
Usually i use short video samples for check video playback. So i watched some movies and noticed the lags. New update fixed it !Last edited by mike77; 18 February 2015, 11:12.
Getting these messages after a few hours of movie watching:
[52760.080507@1] balance_pgdat end zone=1, pgdat_is_balanced=0
[52760.080562@1] balance_pgdat, nr_reclaimed=18
[52760.080574@1] balance_pgdat end zone=1, pgdat_is_balanced=0
[52760.080655@1] balance_pgdat, nr_reclaimed=42
[52760.080666@1] balance_pgdat end zone=1, pgdat_is_balanced=0
[52760.080707@1] balance_pgdat, nr_reclaimed=6
[52760.080719@1] balance_pgdat end zone=1, pgdat_is_balanced=0
[52760.082619@0] balance_pgdat, nr_reclaimed=18
OpenELEC:~ # free -m
total used free shared buffers
Mem: 810 743 67 0 10
-/+ buffers: 733 77
Swap: 0 0 0
OpenELEC:~ #
They start after free memory drops below ~100M, Kodi reports a much lower usage though, subtracting its own usage?
Watched a 1080p movie yesterday and noticed green bars/distortions very rarely, 99.9% of the movie was fine. Before that I just configured mem-caching in advancedsettings.xml, so it buffers when streaming over network. Could the reclaimed memory affect the streaming cache, therefore causing distortions?
Memory will fill up regardless btw, also without advancedsettings.xml.
Just watched another 1080p file over network and no had no distortions, not sure what this is caused by.
advancedsettings.xml:
<advancedsettings>
<network>
<buffermode>1</buffermode>
<cachemembuffersize>157286400</cachemembuffersize>
<readbufferfactor>20</readbufferfactor>
</network>
</advancedsettings>
This will use up to 3x more, so max. 450MB of caching memory.
Apart from the messages above, kodi.log and dmesg look clean.
Originally posted by phinc View PostUI ordered one from geekbuying and i get about 7 Megabytes/sec transfer speed. It is also very cheap:
Bug found?
Since my first run of this rom I got this bug: randomly I get a gray square on the top-left edge of video, like in this photo:
I'm getting it every 15-20 videos (mp4, mkv, avi, youtube streaming... seems to be a random glitch) and appears only when I'm playing video (never show on main menù). The only way to "clean" my screen it's to reboot my mk808B+
Any chance of a more complete HDMI-CEC driver implementation some day? I keep having problems with my LG TV.. Raspberry Pi 2 detects a "Pulse-Eight CEC Adaptor" and everything works fine, but with the MK808B Plus it just doesn't detect anything. I already tried several HDMI cables and adaptors.
Originally posted by Milite777 View PostThank you, I'll try it!
Bug found?
[ATTACH=CONFIG]10472[/ATTACH]
Originally posted by lowridin_guy View PostNoob question, I have an MXQ box. How do I determine if it is made by Beelink of if it is an Acemax model?
This is the beelink:
Just a small update:
Running this for some days on my MXQ S85 now, and overall it's runing really well.
Great work kszaq and codesnake!
Like 5 days uptime and no crashes.
Most movies seem to play flawless, only had this green bars issue, described in my earlier post, once.
Those memory messages still appear in dmesg, and the kodi binary seems to make a certain CPU load all the time, but in general this doesn't seem to affect speed or stability.
I noticed that SPDIF optical audio seems to be slightly behind the HDMI audio, maybe like 300ms; is this a driver issue?
I guess it can be corrected in Kodi settings using a different offset for Audio.
Originally posted by freezer2k View PostThose memory messages still appear in dmesg, and the kodi binary seems to make a certain CPU load all the time, but in general this doesn't seem to affect speed or stability.
Originally posted by freezer2k View PostI noticed that SPDIF optical audio seems to be slightly behind the HDMI audio, maybe like 300ms; is this a driver issue?
I noticed that Kerber/Surkovalex (amlinux.ru) added a patch that might solve this: https://github.com/surkovalex/OpenEL...dio_sink.patch I'll make a test build for you soon.
The patch seems to use 0.250, so 250ms?
That's exactly the value (-0.250) I set now manually in OSD sound settings, which also seem to fix it.
One more thing,
it crashed once more yesterday when unplugging a usb wireless keyboard receiver, so USB seems to be a bit weird. As long as i don't plug/unplug stuff it seems to be stable for days though.Last edited by freezer2k; 20 February 2015, 23:05.
There are currently 1554 users online. 0 members and 1554 guests.
