[ROM] Unofficial OpenELEC for MK808B+ and MXQ
    I keep getting mac discovery failed after I add smb source file. Other than that everything works good
      [ROM] Unofficial OpenELEC 5.0.3 for MK808B Plus and Beelink MXQ
      I also receive this error reporting on my NAS Box but it doesn't affect the video in anyway or the stability of OpenELEC so I'm assuming an immediate fix is not necessary.
        Originally posted by noosk View Post
        Hi kszaq, nice work on getting openelec to these devices. I am intending to purchase an mxq, but am basing my purchase on this software's ability to decode hvec files. Is it possible to do so at the moment?
        Yes, it is. There is a note in the OP that some of them don't play but I have good news: I've just compiled a new kernel from https://github.com/surkovalex/linux-...its/new_kernel and it seems like all of them are playable now! I need to do more tests and will post a test build in a few days.
          Awesome thanks for the response mate. I'll order a unit tonight
            Fantastic, I've been waiting for this, THANKS kszag.
              Maybe you'd rather wait until the tests are finished?
                This easy to fix: just uncheck the option "Try to wake remote servers on access" in Settings/System/Power Saving. I'm not sure why this is on by default, but turning it off gets rid of that error.
                  I don't mind testing, I look forward to trying your releases
                    An update to test then!
                    Short changelog:
                    • amports drivers from Lollipop SDK (thanks to Surkovalex@github)
                    • removed 250ms delay to fix SPDIF on MXQ
                    Kernel source code: https://github.com/kszaq/linux-amlog...er_new_amports
                    Things I noticed that changed for good: HEVC decoding and better-looking deinterlacing.
                    Please test and report:
                    • HEVC videos that did not play with previous releases
                    • 23.976fps fluidity
                    • audio passthough (both regular and HD formats since I can't test this at all)
                    Links (Edit: Update to fix 23.976fps):
                      I am ATM without an 805 device to test, another 808b plus arriving from Gearbest ( maybe 1 month ), drooling following Your work! Thanks!
                      Inviato dal mio Nexus 5 utilizzando Tapatalk
                        Does wake-on-lan working with mk808b+ and this fw? Anyone used it?
                          Short changelog:
                          https://www.dropbox.com/s/2m4rfzp2vb...est-2.tar?dl=0
                          I tested 14/02 version and your latest update. Fantastic!!!
                          Hevc videos that doesn't play with 14/02, works great with this update. Thanks !!!
                            h265 works for me too now, didn't in the previous releases, awesome!
                            Still have some occasional lag/stutter in the videos, not sure if this is related to the many .tar updates I applied?
                            Should a .zip flash via recovery be cleaner?
                            Think the lag started after flashing the first 250ms delay testbuild. Could this be a residual?
                            Can't find anything in kodi.log or dmesg that would indicate a problem.
                            Playing a 23.976fps movie and output mode is:
                            OpenELEC:~ # cat /sys/class/display/mode
                            1080p23hz
                              1080p23hz
                              After applying tar update I too can play H265. I watch allot of American TV Shows and I also receive a slight jerk/lag every so often but not on all files and when I play the same file on my Raspberry Pi Version B using Raspbmc the lag/jerk is not visible but I don't think this is due to this version of OE but more to do with the video that is played around 24fps where the PI using its dated GPU outputs at around 8-9fps rendering the jerk/lag invisible (If I'm wrong here I stand corrected)
                                Fast playback in mp4 files
                                Hi! I'm having an issue playing some mp4 videos, local stored and streaming from internet. Concretly, it's an unusual fast playback ( audio and video ). Is this a known problem? Is there any way to fix it?
                                I have last test release (OpenELEC-Amlogic.MXQ.arm-5.0.3-20150226-test-2) installed in a Beelink MXQ s805 box.
