[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by LeSpark View Post
Originally posted by mrdan View Post
Originally posted by jpalma View Post
Hi kszaq!
Thank you for the hard working to make openelec on my MXQ..
This is great project!
I have hd audio capable receiver, so I can give you information about it.
When dolby hd and dts hd passtrough enabled:
No sound, and video playback slow down.
When passtrough disabled, then dts-hd audio played back just dts core, and dolby hd no sound...
I used Dolby Atmos Demonstration disc 2014
and
TXH demo disc Dolby TrueHD DTS HD movie clips cinema test 2013
Originally posted by nevoz View PostI was wondering if you could please add another resolution. I have a Panasonic TH42PX70A, and the resolution is 1024 x 768 . Could you please add this is a selectable resolution? Everything seems to appear stretched.
Thanking youJust need some free time to work on it, I'll post a test version as soon as it's done.
and
Originally posted by kszaq View Post- There may be some issues with HD-Audio passthrough which I can't fix since I don't own an AV receiver.
@People with an AV-receiver: could you test something for me? Please enable HD-audio passthrough and enter the following commands over SSH (you may get errors after entering them, that's okay):
Code:echo 2 > /sys/class/audiodsp/digital_raw echo spdif_mute > /sys/devices/platform/spdif-dit.0/spdif_mute echo audio_on > /sys/class/amhdmitx/amhdmitx0/config
Originally posted by bajann View PostOdroid-C1 do u have some link to the fw for that device?I hope u will make dual boot openelec with linux or or maybe linux and android,that will be grate
Received my second 808B+ yesterday and Geekbuying gave me a Duff UK power Plug, I did open it but thought its going to be chipped as oppose to a fuze gone. Anyone in the UK that can point me to a seller on ****/Amazon Market where I can pick up a plug with the USB connection where its not one of those Chinese fakes that is likely to give me an electric shock. Thanks Guys
Originally posted by Iso-playback View PostReceived my second 808B+ yesterday and Geekbuying gave me a Duff UK power Plug, I did open it but thought its going to be chipped as oppose to a fuze gone. Anyone in the UK that can point me to a seller on ****/Amazon Market where I can pick up a plug with the USB connection where its not one of those Chinese fakes that is likely to give me an electric shock. Thanks GuysPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by kszaq View Post@People with an AV-receiver: could you test something for me? Please enable HD-audio passthrough and enter the following commands over SSH (you may get errors after entering them, that's okay):
The third row gave me error message:
write error: bad address.
And when playback material with hd audio has the same result what i already say.
Slowmotion video without sound output.
Without enable passthrough dts hd plays just dts core, and dolby hd has no sound.
I think mxq is fast enough too convert dolby hd and dts-hd to multichannel pcm.
I have wetek player too, and i hear from forum this devices processing audio over ffmpeg. There isnt any possibility to switch software decoding as at raspberry pi2?
I noticed with original android system and xbmc after unpacking the mxq the dolby hd video played with sound...Last edited by envagyok; 11 March 2015, 19:13.
I noticed a little CEC problem too.
I want to use MXQ box with cec capable recriver and TV.
Everything worked fine, but after TV switch off (what switched off my receiver too) and I want again turning on the system, my TV and receiver turning on, but MXQ screen isnt coming back, with bundled rc must turning on manually, isnt started automatically.
Maybe later coming a setting panel to cec who everything can I set up?
I know where is the config file, but it is write protected, and I dont have enough skill in Linux to modify it
I like this box... Very fast, with good price thanks again for make openelec to it
Edit:
Sometimes the device lost cec control.
The ssh top command freeze the device.
The Codec info panel only show change percentage of cpu using just for two core, the other two is static..
The system info panel I think show more than real cpu usage.. At idling shows about 40%, what is very high I think.Last edited by envagyok; 12 March 2015, 06:50.
Originally posted by kszaq View PostI try to keep as close to upstream as possible which means that you'd have to wait for a stable Kodi release in next OpenELEC version. Kodi 14.2 beta is what OpenELEC use in the official releases.
But there's a way:- download 5.0.3-20150214 and 5.0.5-20150309 tar from releases page
- untar SYSTEM and SYSTEM.md5 from 5.0.3 release into Updates folder
- untar KERNEL and KERNEL.md5 from 5.0.5 release into Updates folder
- reboot your box
After doing that you will have Kodi 14.1 with the latest kernel-side improvements.
Originally posted by kszaq View PostI am planning to add support for more resolutions by copying the code from Hardkernel's Odroid-C1 kernel.Just need some free time to work on it, I'll post a test version as soon as it's done.
Hello Envagyok, good to see you thoroughly testing the release.
Originally posted by envagyok View PostAnd when playback material with hd audio has the same result what i already say.
Originally posted by envagyok View PostI like this box... Very fast, with good price thanks again for make openelec to it
Edit:
The system info panel I think show more than real cpu usage.. At idling shows about 40%, what is very high I think.Code:echo ondemand > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
You also shouldn't worry about the load shown in System Info tab. I think the reason might be that it is calculated in relation to current CPU operating frequency which changes depending on the load. If you want to see absolute load, you may typeCode:echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
There are currently 2621 users online. 3 members and 2618 guests.
