[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by mikesheadroom View Post
Today evening (CET) I will post an update with a fix in kernel (by @codesnake) that would probably fix CEC for some of you. Keep in mind that CEC does not work with cable supplied with MK808B+, you need to use a better one.
The update will also include a fix in Bluetooth initialization script to fix config uart_ao_ttyS0 dmesg spam.
I will also look at the hardware decoding problem.
That CEC patch is really working, in the meantime a workaround is echoing "0xb" to the cec_config sysfs file, I noticed it today playing with my CEC and my new Panasonic TV, that fix though works with every CEC configuration. Codesnake is a beastWeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
Originally posted by ChristianTroy View PostThat CEC patch is really working, in the meantime a workaround is echoing "0xb" to the cec_config sysfs file, I noticed it today playing with my CEC and my new Panasonic TV, that fix though works with every CEC configuration. Codesnake is a beast
Originally posted by Iso-playback View PostShame my poor old Samsung UE32H5000 is lacking in CEC support. Why do Samsung only release CEC as part of a Smart TV, if you dislike smart TVs as I do you suffer by losing out on CEC. Come on Samsung sort it out.
Originally posted by goofball View PostI have a very old Samsung that is definitely not Smart and it has CEC. I mean, the remote doesn't even have a way to program other devices, lol. I also have a Toshiba that is not smart and has CEC.
Originally posted by kszaq View PostA small update:
Edit: Did a fresh install via toothpick.
I recently had problems with an addon that might be caused by the kodi 14.2 beta in the latest releases.
So my questions are:
@all: is it possible to downgrade via the tar-update method?
@kszaq: is it possible that you add all your great amlogic, cec etc. patches but keep kodi on a stable release? I think that would benefit many users.
Originally posted by LeSpark View PostThanks for that, but unfortunately it didn't solve my problem with the MXQ and CEC. Here's a new dmesg in case it helps:
Edit: Did a fresh install via toothpick.Code:cat /sys/class/amhdmitx/amhdmitx0/cec* | paste
Originally posted by phinc View Post@all: is it possible to downgrade via the tar-update method?
Originally posted by phinc View Post@kszaq: is it possible that you add all your great amlogic, cec etc. patches but keep kodi on a stable release? I think that would benefit many users.
But there's a way:- download 5.0.3-20150214 and 5.0.5-20150309 tar from releases page
- untar SYSTEM and SYSTEM.md5 from 5.0.3 release into Updates folder
- untar KERNEL and KERNEL.md5 from 5.0.5 release into Updates folder
- reboot your box
After doing that you will have Kodi 14.1 with the latest kernel-side improvements.
Originally posted by kszaq View PostIt seems from your log like there is a CEC conection. Can you doCode:cat /sys/class/amhdmitx/amhdmitx0/cec* | paste
Originally posted by LeSpark View PostSure: http://sprunge.us/VhIJCode:echo 0 > /sys/class/amhdmitx/amhdmitx0/cec_config echo 0xb > /sys/class/amhdmitx/amhdmitx0/cec_config
Originally posted by kszaq View PostOkay, that means that there is no CEC communication between the devices. Could you try what @ChristianTroy suggested earlier? That means:Code:echo 0 > /sys/class/amhdmitx/amhdmitx0/cec_config echo 0xb > /sys/class/amhdmitx/amhdmitx0/cec_config
network usb 2.0 dongle
Hi
I bought this usb2.0 network dongle (like in the post #28):
http://www.geekbuying.com/item/High-...et-314264.html
When I plug it in for the first time it work, if I reboot the network dongle don't want to power on.
And if I go (after reboot) in OPENELEC->CONNECTIONS , WIRED CONNECTION is DISABLE, and when I click on it, it stay disabled.
Do you know why ?
There are currently 4059 users online. 0 members and 4059 guests.
