[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by djnice View PostIt's not true. You can play smoothly the 720x576i on Amlogic.
Originally posted by Iso-playback View PostI must by lying then??? It is true if you play on 1920x1080p I have a Pi B and I tried with that on full res and it was fine at a bad fps rate then on 808b Plus full res it stutters. My test is completely true. What you have said is that if you use very low res such as what you describe 720x576i but even then I only have 808B+ and that low res is not present.
@djnice, @envagyok: I will take a look at the video that stutters and see if I can do something about it.
Originally posted by envagyok View PostI try play multichannel flac music, but MXQ can output just 2 channel pcm over hdmi.
Mxq capable multichannel output over hdmi?
I have a little issue too.
I have cec TV, receiver.
When I turn off TV, receiver shutted down, and mxq go standby (not powered off).
After that, when I turn on TV, receiver powered too, but for mxq must use ir controller.
When I turn on mxq the no booting process, after 1 sec there is a menu.
So cec wake up isnt working for me.
Anything else with cec is ok.
Originally posted by djnice View PostI noticed, the dvd upscaling quality is poor.
This is an example (hdmi capture):
Beelink MXQ with Openelec:
Samsung BD-F5500:
It's an Amlogic or Openelec fault?
Originally posted by bajann View PostCan u try that with android o.s and mx player or xbmc?
Similar to the Openelec, but with less noise.
Samsung BD-F5500:
Originally posted by kszaq View PostHere's another experimental release (untested, it may break things!):
Please test and report:- multichannel PCM audio
- HD Audio passthrough
- DTS and Dolby Digital passthrough
For MXQ users: after this update optical output will most likely not work.
Maybe fresh install help?
Originally posted by envagyok View PostI update existing 20150315 version, and absolut no sound. At music,at movies, dts,dolby d, with or without dts-hd, dolby hd passtrough, just silenece.
There are currently 3314 users online. 1 members and 3313 guests.
