[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by AcidHaze View PostThanks for the reply. I had to resort to a complete wipe, not just dalvik and caches. Got wifi back up and running, now testing a version of Megatron ROM. Please let me know if you can make this ROM compatible with my box in the future, complete ROM was dumped on page 1! Apparently it has different BT and Wifi, plus I only insert SD card halfway and it can't go further so I'm thinking new model.
Originally posted by sunnythakkar_2005 View Post
Originally posted by Dez View PostThe more I use the MK808B+ and this port of openelec, the more I'm impressed with it.
I managed to get CEC working with my 5 year old Samsung PS58B850 plasma after getting a mini-HDMI adapter and trying several HDMI cables.
It definitely has a lot to do with what cable is used, many (cheaper types) don't work at all.
The only problem I have now is that while I can switch the MK808B+ off (or more correctly, to standby) with the TV remote power button, nothing on the remote will switch the MK808B+ back on when the TV is turned on.
To get it to turn back on, I have to unplug and reconnect power and get the TV to detect it again before it works.
Is this how it works for everyone else?
Originally posted by Iso-playback View PostYou need to be careful my friend as that box may not be Beelink and also go to Geekbuying its cheaper delivered direct from China, you just wait a little while. I noticed tinydeal that are also trading from UK which is not good as you pay more.
I dont think that site is much cheaper tbh as there is the likelyhood of UK import tax and customs to pay.
Originally posted by silverblack View PostThe original rom installed back ok its only a spare box for the kitchen.
Originally posted by kszaq View PostTo power on a box on my old Samsung LCD TV (B-series), all I need to do is hit "Menu" button, choose "Anynet+ Devices" and then "MBox". The box wakes up over CEC then. I like it that way because my MK808B+ wakes up only when I want it to, not every time I turn on my TV.
That method would be preferable to me too.
Unfortunately mine just shows "No Devices" (even after refreshing) when the MK808B+ is in standby. I have to unplug and re-connect it before "MBox" appears again.
It's not too much of a problem.
I'll try some more HDMI cables and also see if there is any firmware upgrade around for the TV that might help.
I think it is possibly a problem with the TV maybe not providing a (or the correct) "wake up" signal over HDMI (Anynet+) when it is turned on via the remote.
Originally posted by Iso-playback View PostThis is a minor bug which is temporary resolved after a reboot. The developers are aware of it and that I'm sure it will be resolved at a later date.
Has anyone found the cause of this problem? Am I the only one experiencing this?
Thanks!
Originally posted by mikesheadroom View PostI am experiencing this "minor" bug on every video I try using both versions 5.0.3-20150214 and 5.0.5-20150306 using 1080P output. If I use 720P output, the entire screen is filled with the garbled video stream. I have tried reboots and hard power cycles and it persists on every video. I am using this unit: http://www.amazon.com/gp/product/B00Q9NOQPM/. Kodi works just fine for me when run under Android.
Thanks!
Originally posted by xitpu View PostHello,
I am not able to have CEC working with my Panasonic 50VT60 Plasma.
I have only the standard hdmi cable.
Any suggestions ?
The one that comes with the mk808b+ does not work with CEC. I have an adapter and 2 mini hdmi cables coming to see which will work with CEC and my Samsung TV.
Originally posted by kszaq View PostThey fixed CEC for my TV, they might also have bugged it for yours.
Also in case it helps, when i startup my Raspberry i get a notification about an "Pulse-Eight-CEC-Adapter" which is just missing at the MXQ.
There are currently 2954 users online. 0 members and 2954 guests.
