[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by tsfamd View PostHi Kszaq,
I didn't see any question about this, but do you think that is possible to use MK808BPLUS with a USB DVB Tuner, like HTC Terratec HD (features a empia 288xx chipset), with TVHEADEND, with your Openelec port?
Both tuners appear and work in Openelec.
I don't think the OTG port provides enough current for this tuner to work properly.
The Leadtek DTV dual dongle (IT9137 + IT9133.....seen as dual IT9135) also works.
Originally posted by maria33 View PostHi,
How do you control your Mk808B plus? Can it be controlled by phone app? Which one?
If so, after you flash Openelec in it, can it still be controlled by phone?
Yatse won't work straight away after flashing although it may pick it up.
http://www.geekbuying.com/item/Trons...0305_sku317283
works very well, with keyboard (with backlight keys) , touchpad and very cheap.
With the OpenElec porting works great also the TV Samsung remote through the CEC protocol (with the android stock firmware not works).
Originally posted by clarkss12 View PostI have 2 of those remotes and they are great for Android, but for Kodi or OpenELEC this is the best remote.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Power button on remote
Thanks all for your hardwork for openelec getting to work on mxq boxes.
I have updated to latest ver 5.0.3 for my MXQ box and working great.
The only problem i have is that my remote control is not responding. I have following remote control:
Any help will be greatly appreciated.
Thanks,
Hey guys please help! I think I bricked my wifi bad with this one...I thought I had Beelink so I flashed it but it turns out I have some MelzerTV box, and their firmware and support is nonexistant and I factory reset my XBMC out of frustration...
Anyway I just want my wifi back. It turns on and connects and obtains IP address etc everything but cannot connect to anything, just a white icon in the background when it's supposed to be blue I think.
Is my box wifi bricked forever? There's no way it physically damaged the wifi card (I think), but I tried clearing dalvik cache and cache using TWRP and still nothing...
What to do? I just want my wifi back good sirs!
Thanks!
Originally posted by sunnythakkar_2005 View Post
Originally posted by AcidHaze View PostHey guys please help! I think I bricked my wifi bad with this one...I thought I had Beelink so I flashed it but it turns out I have some MelzerTV box, and their firmware and support is nonexistant and I factory reset my XBMC out of frustration...
Thanks!
Since I can't edit the OP anymore , I am posting a new release announcement here:
5.0.5-20150306- OpenELEC 5.0.5 (by @OpenELEC team)
- amports and deinterlacer in kernel updated to Amlogic Lollipop SDK (thanks to @surkovalex for providing the source code)
- removed 250ms latency on SPDIF for MXQ
- fixed HEVC playback (thanks to new kernel and a patch from @koying)
- fixed playback of 23.978 VC-1 videos in MKV container
- some minor fixes to video playback in Kodi by @codesnake and @davilla
- refactored Bluetooth support so that it does not need to be power-cycled on every reboot (an idea by @codesnake)
Of course you don't have to wipe all your data, simply download a tar and update according to OpenELEC guidelines.
Are you saying that now the HEVC videos with problems are now playable ?
(for example https://mega.co.nz/#!Ug4yhKBB!fbDsyW...dscF_z0WDbg_AI )
Thanks!
- some HEVC videos won't play using hardware decoding (issue also present in Android)
There are currently 2182 users online. 9 members and 2173 guests.
