[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by gcsuri View Post
You may provide only the nand_env instead of the full bootloader. I think it's more safely.
Possible CPU overload / over heating!
This relates to the MXQ 6.0.0.1 build and possible the previous build which also had this glitch on a number of occasions. It's an all black MXQ box. My TV screen flashes black for a second and then reverts to Kodi it does this several times and sometimes keeps doing it forcing me to reboot. It may be something to do with the refresh rate switching on my TV stumbling but I'm slightly concerned it may be the CPU. And yes all four cores are running. K's recent comment about having two boxes die is slightly worrying!
I was going to review the 6.0.0.1 build but it seems we all agree it's fine and seems slightly improved mainly because of the incremental update of Kodi.
I've had a nightmare with my box until recently so I'm not rushing to update until I know a build is reasonably stable. Having said that I'm looking forward to the Jarvis release which will obviously be sometime coming and will probably be the point at which I will accept that my box has reached it's full potential.
As a side note: it would be nice to get the Wifi working but it's not a deal breaker as I'm pretty happy with K's build. This post will help new people decide which version of K's build to run on their MXQ, also note that the Wifi is mentioned as being crap which I've heard several times in the past. Will photo my box when I get a mo and add it to the thread. http://freaktab.com/forum/tv-player-...736#post551736
kszaq Looks like ethernet speed improved a bit in this last version like +6/7Mb!
Some of the things that i noticed that are missing or not working properly:
- Only english is available for system languages.
- Menu transitions are not smooth yet.
- In sports devil add-on (this happened also in previous versions) the time displayed in the games list is allways one hour in advance.
Thanks for your work kszaq amazing
MK808b Plus @ gearbest
Originally posted by sonofdibnah View PostReverted back to 6.0.0.1 with no problems on the MXQ beelink red. Now I know I can do it, I'm looking forward to the next attempt kszaq. I'm more than happy to test as I can understand how difficult it can be without your box.
Diese Website steht zum Verkauf! s805.eu ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf s805.eu alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Works fine on my MK808B+.
As a side note: it would be nice to get the Wifi working but it's not a deal breaker as I'm pretty happy with K's build. This post will help new people decide which version of K's build to run on their MXQ, also note that the Wifi is mentioned as being crap which I've heard several times in the past. Will photo my box when I get a mo and add it to the thread. http://freaktab.com/forum/tv-player-...736#post551736I will try to find device's manufacturer and reach out to them for u-boot source code so that I may compile updated kernel. I hope they will want to cooperate.
As for CPU-related issues, you may want to downclock your CPU a little bit by adding the following command to autostart script:Code:echo 1250000 > /sys/bus/cpu/devices/cpu0/cpufreq/scaling_max_freq
Originally posted by kszaq View PostThank you for the tip. Can you share some more information on this, an example? Does it allow to change u-boot scripts, like in this commit: https://github.com/kszaq/u-boot/comm...59c86b3a217216 ? This is the only thing I need to make booting from SD card work.
I think there is more way to write the uboot variables on S805.
- if you are root on factory android firmware you can use setprop ubootenv.var.VARIABLENAME 'VALUE' syntax - I think there is a limitation, because longer values aren't written...
- recovery binary has a function set_bootloader_env("name", 'value') function. you can put it into the updater-script.
- there are fw_setenv/fw_printenv tool - need to compile the binaries.
- dump the whole nand and write back - I don't know how because on some kernel it's a character device.
best regards, gcsuri
Good morning. Tried 6.0.0.2-3 just now. It boots to the Openelec screen and stops there. I've tried a couple of reboots but its the same each time. There's nothing more I can say about it apart from it looks better than the screen full of text!
I've got guests staying with me but I'll do my best to be prompt in reacting to updates.
I just updated to OpenELEC-Amlogic.MXQ.arm-6.0-devel-20160124000647-r21605-gadbddbe.tar but unfortunately it does not boot. Just a bunch of errors on screen
Picture attached. Dont know if its any help? I have a red stripe MXQ
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by mylle View PostI just updated to OpenELEC-Amlogic.MXQ.arm-6.0-devel-20160124000647-r21605-gadbddbe.tar but unfortunately it does not boot. Just a bunch of errors on screen
Originally posted by sonofdibnah View PostGood morning. Tried 6.0.0.2-3 just now. It boots to the Openelec screen and stops there. I've tried a couple of reboots but its the same each time. There's nothing more I can say about it apart from it looks better than the screen full of text!
kszaq : if this can help, on my RED mxq, i have:
1. Tried the TV110 version : same issue as mentionned up.
2. Tried the MK808B+ version and:
- It boots correctly
- HDMI CEC works
-- the only issue i notice ; there is no sound with HD videos when Passthrough is enabled.
Regards
same for me , mxq red stripe , boot stay at openelec logo.
but for testing i tried install update .tar for mk808b+ on my mxq and works ok , boot up normally
There are currently 2214 users online. 1 members and 2213 guests.
