[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Awesome work Kszaq on bringing OE to AML. I new to this forum and have been looking for AML OE build for a while. I just discovered your build
I have 2 MX boxes:
1. MKv : http://www.aliexpress.com/store/prod...342186647.html
2. Beelink with Red strip on the top
Questions:
1. Which ROMs should I be using , please provide me the links
2. I once tried another OE Rom on my MKv but I wasn't able to turn on the WIFI and was also not able to set the Display to 1080p
3. Is there a OE firmware available for M8s S812 ?
Can someone assist me THANKS !
billo
Originally posted by phinc View Post
i have extracted remote.conf from original android rom and put in openelec configfiles folder.
problem is all key in remote works except the OK button,
without ok button not working ,useless.
what should i do?i been using wireless airmouse right now.
another issue is wifi not stable.
i see 2 ssid in wifi same repeated,i connect to one but disconnects after few minutes and connects again.
when i reboot device ,wifi doesnt connect automatically.
Think the problem is you are trying to use a rom for the mxq red in a mxv s805 device. These are two different devices.
Originally posted by billo View PostAwesome work Kszaq on bringing OE to AML. I new to this forum and have been looking for AML OE build for a while. I just discovered your build
I have 2 MX boxes:
Questions:
billo
1. 2. "MKV" box is not supported. For the second one you should use MXQ version, links are provided in OP.
3. Not from me, you should search the forum and maybe someone builds for M8s.
Originally posted by billo View PostI forgot to ask, How to extract the " extract remote.conf from the Android ROM for your device and put it into Config folder "
billo
Originally posted by jackmate View Posti have extracted remote.conf from original android rom and put in openelec configfiles folder.
when i reboot device ,wifi doesnt connect automatically.- Login over SSH.
- cat /proc/kmsg
- Press OK button and note the message that appeared in the log.
- Look for the keycode in remote.conf and change it to 28.
You haven't provided any logs so I'm unable to give you any hints on WiFi issue. Please also not that I don't support this device.
You may either copy it using a file explorer in Android or extract it from zipped Android firmware update. You'll find the file in /system/etc folder.
Guest About OK button, you can do the following:- Login over SSH.
- cat /proc/kmsg
Ok button in remote works now after changing code for ok button in remote.conf file .
Only other issue now is wifi,
2 wifi name appears for same ssid,
Once I connect ,it drops out and when reboot wifi doesn't connect ,get error in wifi connection .
What logs do u want ,I can provide
Hi ,
Thanks kszaq !
I installed the 5.0.8.18 on my MXv S805 and it seems working so far :-) I have MXQ black and Red ordered so as soon as I get those boxes I will try same. now i need to find M8s rom..
I have another question , 5.0.8.18 has the Google TV boot screen , i need to change it to my own boot logo. I am able to change the OE spalsh screen which is the oemsplash.png,
http://sprunge.us/gOGV
after reboot :
Originally posted by rev6 View PostMXQ. 5.0.8.18 just crash now. Video froze and audio looped. SSH won't seem to connect for dmesg.
Originally posted by jackmate View PostI did flash HD18q build ,with that no wifi is shown in openelec. I flashed mxq red openelec build back ,wifi is there but 2 wifi name eth0 and eth1 for same wifi.connected to 1 and if box reboot,wifi is lost and doesnt connect automatically,get failed message.and here is dmesg
after reboot :
http://sprunge.us/WTMB
Hi kszaq
Thanks for your great work.
I've installed your 5.95.3.1 test version and i found this.
It works but...
Only in english, no hotplug governator for the cpu and when we boot the device (mxq) several lines like in old ms-dos.
It is possible to remove the google tv splash screen and put the openelec logo at boot?
In the final release will fix this?
Cumps
Originally posted by kszaq View Postrev6 I have experienced several crashes with my MXQ recently and what helped is changing CPU governor to hotplug on boot. This will be a in a next release. If I remember correctly, you reported a "chipmunk sound" issue some time ago. I was able to reproduce it but I'm still working on a fix.
It works but...
Cumps
These "MS-DOS lines" are actually a kernel log and I like to have it there but you're right, I may want to get rid of it in the future...
The "Google TV" splash is from original firmware. If you change it to something else, my latest releases won't change it. Look at my previous post to read how to change it. If you want to use an OpenELEC logo, you can download logo.img from my previous releases: https://github.com/kszaq/OpenELEC.tv...files/logo.img
Originally posted by rev6 View PostOh good I thought I might have been the only one with the crashing. Thanks. I haven't had issues with "chipmunk sound" just a lot of the time audio is slightly ahead of video. -0.250 audio offset fixes it. p8 is still the best here for audio/video sync.
Here's a changelog between 5.0.8p8 and 5.0.8.18: https://github.com/kszaq/OpenELEC.tv...8p8...5.0.8.18
As you can see, there are no changes that may have affected audio sync and honestly I'm out of ideas what may be causing them for you.
There are currently 4067 users online. 3 members and 4064 guests.
