[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by pigbait View PostAnyone else having WiFi failure on 5.95.5, I'll post log tomorrow to help with diagnostics.
I thought I was also seeing this wifi going out and not connecting, but I found that it was a setting in my router that I had changed...(Turned the 2.4Ghz to "N" only) when I did that I was unable to connect to the wifi...After setting the router back to "B,G,N" on the 2.4Ghz...My mk808b plus connected again!!
Try this setting in your router.Last edited by sammaz; 15 September 2015, 07:03.
Hi Kszaq, it's been a while since I last wrote something on this forum but have been using your amazing releases ever since.
I have just updated from 5.0.8.20 to 5.95.5-1. I had a custom MX2 remote.conf file working well before I updated, but since the update this hasn't worked. The file is still there - and for good measure I deleted it and reloaded it - but it simply doesn't work. Do I need to put the remote.conf file in another location for Isengard?
I've been running OpenELEC from SD card for over a week from my new OTT MXQ and ever since I installed it I couldn't boot into Android anymore. This was not a big deal because I was still testing and trying everything. However, I wanted to flash OpenELEC to the NAND but I was not able to do so. I figured I would try flashing some Android images but
Whenever I get into recovery I get the error "Can't mount cache". Because of this I can't flash anything, no recovery images or Android / OpenELEC images there is always an error mounting some partition.
I believe these errors occur because my partitions are screwed up, could that in fact be the problem? I can boot into TWRP from SD card and from the terminal I ran the command "df", this is what it shows:
Also when trying the option "Repair or Change File System" on the cache, data or system partitions they show up as size 0 mb.
In the past I repartitioned an Android phone from recovery using adb, I hope I can do the same with this TV box. Can anyone share their partition table for their OTT MXQ with me please? It would be great if there is a way that the partition table could be dumped and I could simply flash it so I wouldn't have to do it manually.
Despite all this I can still run OpenELEC from SD btw.
[EDIT, SOLVED]
Managed to fix it by flashing an image using the USB Burning Tool. For reference, exact steps can be found here:
Hello,
i want to use vpn services, but when i go into the openelec addon it isnt available under network. is this a bug from my side, or is this not available in this version of openelec (i am using the unofficial openelec for MXQ v 5.95.1)?
if it isnt available is there another way i can use vpn?
thank you for your time
There are currently 2146 users online. 0 members and 2146 guests.
