[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Can someone please help me, I just received my mk808b+ today from gearbest and the sole purpose of it was to install Openelec as I already have a minix neo x6 with android and i wanted a openelec device. Although I cant seem to get it to boot into the recovery menu using the toothpick method. Any help would be greatly appreciated. Also im using a firestick plug to power it, it has 1.8a and the one supplied with the mk808b+ is 2a would this make any difference ?.
Originally posted by adam45417 View PostCan someone please help me, I just received my mk808b+ today from gearbest and the sole purpose of it was to install Openelec as I already have a minix neo x6 with android and i wanted a openelec device. Although I cant seem to get it to boot into the recovery menu using the toothpick method. Any help would be greatly appreciated. Also im using a firestick plug to power it, it has 1.8a and the one supplied with the mk808b+ is 2a would this make any difference ?.
Do one thing.....boot to normal android and there open a terminal...enter the following commands
su ---> to get into root mode ( a popup may ask you to grant root permission, just grant it)
reboot recovery --> enter this command next...it should boot into the recovery menu (make sure you have the sdcard fitted in before doing all this and the openelec img installed using say Rufus)
Hope it helps....
I am completely new to this forum. So sorry if I am a bit of a noob or am asking painfully obvious questions but I can't seem to just automatically understand the lingo here.
First where is the "NAND release folder"?
It is mentioned but I don't see it anywhere. Feel free to include screen caps or links since as far I can tell no one else needed them but I am too dumb to just have been born knowing where it is like the rest of you. Please talk to me like an idiot, I already feel like one since I seem to be the only one who has missed this important detail.
Second where is this "img.gz" this too was mentioned as if everyone in the community would just know where it is. Well I'm sorry but I am the one idiot unable to figure where the hell it is.
I'm not sure if these questions were answered in previous posts as I only read the first 10 pages. It is wholly possible the solution was in one of the proceeding 70 pages but at this point I decided it would be easier to have one of you berate me for my stupidity by asking than to try to figure it out on my own.
Thank you for your help in advance.
Originally posted by Davey View PostHi looking for a cheap option for open elec, is this the box I am looking for?
Couple of questions is wifi any good on these router is same room but about 15 foot away? Can you use pia with the rom?
I have ordered tvstick. After two month of waiting they told that my purchase was lost, and proposed me to pay another 50% of the purchase. Since I did not paied for insuarance (I do not remember if it was available during ordering process).
Read More at : freaktab.comhttp://freaktab.com/forum/tv-player-support/rk3688-devices-aa/beelink-rk3368/530299-i68-tv-box-firmware-upgrade-16th-october-2015
Originally posted by jesusodin View PostHello guys;
Just wondering if this openelec is safe to install on a MK808b+ with the M805 chip and the AP6212 wifi chip.
Thanks for your help....
jo
Download\extract these 2 .zips :
and
put all of the files in the root of your SD-Card and then reboot with the toothpick\reset button pressed.
Originally posted by Jenesis83 View PostThank you mailkit. I did try, that link is listed nowhere in this forum or anywhere else. I am now apart of the special group who has access to it. Thank you.
Follow these steps for the following releases.
In the very first post you will find links to current releases:
Actually pretty hard to miss them.
That will take you to releases webpages, when you have changelog, instructions, etc. Scroll down past the FAQ and you will find the link to the file folders:
I'm currently using a HD18Q based MXQ device which is working flawlessly with OE 5.95.5.2. (Thank you so much for the support kszaq!).
However I would really like to use a full blown linux distro like the one mentioned here, but I can't seem to get wifi to work and it's pretty unstable on my device.
I guess it's due to the kernel (at least for the wifi part where it's lacking proper drivers). My question is would it be possible to use the kernel from kszag in a full blown linux distro and if so could anyone provide some pointers in how to achieve this (including the steps for making a flashable image)...
Hi guys... i have followed the sdcard instruction and have downloaded the stable version for hd18q ... unpacked the image with zip but i only have 3 files not 5 like instruction said... am i doing somethimg wrong.. i dont want to intsall to nand only sdcard to see if i can use on my box.... if someone can help me .. just dont want to make a mistake..
Originally posted by didiram View PostAfter changing to openelec on the nand the orirginal remote control is not working, Can someone knows how to fix it ?
If everything else is working fine, you only have to copy the correct remote.conf in the Configfiles samba share.
Originally posted by fcp.08 View PostHi guys... i have followed the sdcard instruction and have downloaded the stable version for hd18q ... unpacked the image with zip but i only have 3 files not 5 like instruction said... am i doing somethimg wrong.. i dont want to intsall to nand only sdcard to see if i can use on my box.... if someone can help me .. just dont want to make a mistake..
If you want to install FROM the SD card, follow NAND instructions and NAND files.
If you want to install TO the SD card, follow SD Card instructions and SD files.
There are currently 2459 users online. 0 members and 2459 guests.
