[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by jm_maclaren View Post
While that works, the video playback stutters and drops frames despite the fact the four cores sit at about 60% each. HW decoding plays perfectly and leads to about 20% on each core. I was playing via the mythtv pvr a h264 720p recorded on my hdpvr
what version are u running?
Hello.
I have tested USB tv tuner that is using popular chipsets - RTL2832U+R820T. E.g. http://www.aliexpress.com/item/USB2-...396245518.html
This tuner have been found in Tvheadend webgui, but I had stability problems with tvheadend and my black MXQ box. So I'm still using it with my old Asrock ION minipc with Kodibuntu.
I have used tvheadend build from experimental Weetek Openelec repository. I guess that this could be improved now after OpenElec 6.0 final release.
I have MXQ (with red text top) and the latest 5.95.5
I connect to my nas and tvheadend server via ethernet.
I use tvheadend client to watch TV channels with box.
I explore a interesting thing..
When i want to see recorded TV shows then the playback is choppy, not fluidly.
When I turn off wifi, the plays this files good (all of times I use ethernet wired connection)
So why play back recorded TV shows good or bad quality depend wifi is turned on/off, when my box connected to ethernet by cable?
Hey guys,
New to the forum.
I have been using this on my nexteon MXQ for awhile now and it works great! Thanks to kszaq for all the hard work!
I've recently bought the OTT MXQ off Amazon for the 4 usbs and wanted to load the NAND version. When I boot into recovery with the tooth pick method and try to update for ext (USB or SD) it is unable to mount them.
Has anyone run into this?
Thanks !
Originally posted by Dmc99 View PostHey guys,
New to the forum.
Thanks !
There are currently 2097 users online. 0 members and 2097 guests.
