[ROM] Unofficial OpenELEC for MK808B+ and MXQ
fcp.08 Judging by the pictures you send I find it strange that the HD18Q rom isn't working... According to the specs of the RTL8188ETV it's an USB based chip and since my board uses the same chip and works perfectly fine I'm wondering if there isn't something else going wrong...
Although my board has a higher revision and differs slightly from yours...
The only thing I can imagine is that on your revesion of the HD18Q board the wifi chip is connected through gpio. But I'm lacking the proper knowledge to verify that...
So again my question, are you ABSOLUTLY sure that the wifi works properly with the stock rom?
For example if you have a look at this image you can see that the wifi chip board that is used in your device is based on an usb interface...
Originally posted by Spekkie View PostGuest Judging by the pictures you send I find it strange that the HD18Q rom isn't working... According to the specs of the RTL8188ETV it's an USB based chip and since my board uses the same chip and works perfectly fine I'm wondering if there isn't something else going wrong...
For example if you have a look at http://i00.i.aliimg.com/wsphoto/v0/2034756994/Free-Shipping-RTL8188ETV-new-WIFI-module-.jpg_350x350.jpg"]this image[/URL] you can see that the wifi chip board that is used in your device is based on an usb interface...
This is way over the technical thinking for me...
I have gone back to 5.08.20 hd18q rom ... playpack of live tv way much smoother... anyone know of commands that i might try and see if we can get this wifi working.... apart from that i am so happy with this unoffical openelec for the mxq .... great work you geniuses. .!
Originally posted by Spekkie View Postfcp.08 Judging by the pictures you send I find it strange that the HD18Q rom isn't working... According to the specs of the RTL8188ETV it's an USB based chip and since my board uses the same chip and works perfectly fine I'm wondering if there isn't something else going wrong...
Originally posted by sammaz View PostMaybe just a cold solder joint ? From your pic it looks like the board with the RTL8188ETV is a seperate unit from your mainboard. You could put a drop of flux on each of the contact points and do a quick dab of solder to make sure they all have good contact with the mainboard.
anyone know why i get this error when I try to compile from ubuntu 15.10?
**** The following packages were not installed correctly ****
md5deep
Makefile:18: recipe for target 'amlpkg' failed
make: *** [amlpkg] Error 1
I have tried installing md5deep but it doesnt fix anything? its been like this for 3 days
I've also tried sudo apt-get install md5deep still same problemLast edited by pigbait; 27 October 2015, 05:22.
Originally posted by pigbait View Postanyone know why i get this error when I try to compile from ubuntu 15.10?
md5deep
As of ubuntu 15.04 they've changed the md5deep package and this issue has been resolved in the main OE git repo a few days ago.
What I needed to do to get a working environment is to install these packages:
- build-essential
- gcc-multilib
then apply the patch attached to this post in order to fix the md5deep issue.
Clean and restart building.
Originally posted by Craigthered View Post
Thanks for looking into this. I tried the modprobe command as suggested but it failed.
(from AliExpress Android)
Will this USB wifi adaptor work? Says realtek rtl8192eu
Hello everyone. I'm sorry for being absent for such a long time and I need to ask you for some more patience - today I am leaving for my honeymoon and I'll be back after 10th November.
It's very nice to see you helping each other in this thread. You're also welcome to post suggestions and pull requests for future builds which I'll review when I'm back. Custom builds are also welcome.
I am also very grateful for donations I received. As there has been very little work on my side recently, I forwarded them to Kodi and OpenELEC teams. I hope donors don't mind.
There are currently 5800 users online. 1 members and 5799 guests.
