[ROM] Unofficial OpenELEC for MK808B+ and MXQ
    Originally posted by Spekkie View Post
    pigbait I installed the packages mentioned here:
    fcp.08 thanks for sharing the rom, I'll have a look at it asap...
    hi spekkie , have u had any luck with the stock rom i supplied, just wondering if you have had progress or its not looking good..
      Openelec 6 for mxq
        Originally posted by envagyok View Post
        Openelec 6 for mxq
        How is this version working for you?
          i have original mxq (red text), and i try to install, but doesnt make it. Then i download latest kszaq nand install, then copy over the update file and renamed to 5.95.5.2. then installed.
          I think recovery.img is bad.
          I tested it, work, but not perfect.
          No wifi, remote and cec sometimes stop responding, but with android remote Ok.
          Color remote keys used for other functions, so no options with blue key.
          I flash back latest kszaq
            Originally posted by pigbait View Post
            thanks allot for you help that fixed it.
            for anyone with a black MXQ with a realtek 8189es wifi, I made a build that seems to have working wifi. if anyone want to test it out... kszaq work is by far better then mine so this is only till he gets back.
            download link:
            https://mega.nz/#!0ltmEZbY!Aw8E1Erv1...ORCzkzXBO3tOcg
            ***you may need to set "wait for network before starting kodi" in openelec network settings i set mine to 30sec***
            Wifi appears to be working, I can ssh on anyway but resolution and remote not, remote is no biggie as I can add the remote.conf from a working box to fix but any idea how to go about fixing this?
              I tested this for kerber and it works well
                Hi, sorry for my absence, but I've got the keys to our now place last Monday, so I've been busy with our new place...
                I haven't had time yet to look at the stock rom, but I will return when we're settled in our new place
                  Awsome on your new place man. Have fun.
                    I box i had froze on the openelec logo ,i had to reinstall to get it going again.
                    I cant remember if i had auto updates on would that have froze the box ?
                    Ive now got it on manual updates so it doesnt try to update to OE 6.
                      When I format the miCROSD card, does it have to formatted in FAT32 before dragging the 3 files on it?
                      I dont have an SD card reader but i was thinking of doing the followin:
                      1. Formatting my spare microsd card using my android phone using the android menus
                      2. Download and extract the ZIP file to the microSD card
                      3. Pull the mSD out and plug it into my BeeLink to flash with OE
                      Will that work?
                        Does anyone know how to fix constant blue light on when i poweroff 5.59.5.2 hd18q ..... all working .. just constant blue light always ...can this be fixed somehow...
                        Spekkie congrats on the new place... no rush on the one...
                        Got myself a clone to play with and wifi works onthis one.. just issue with blue light always on....
                        How do i go about cloning this settup and tweeks i did to the other mxq i have .... thanks guys.. love this forum
                          Is any hope to update mxq OE to 6.0.0?
                          When i flash from amlinux.ru, it working much better except infra remote, and wifi
                          Or how can i compile the update personally?
                            A slightly old kszaq release (https://github.com/kszaq/OpenELEC.tv...s/tag/5.95.5.2) is based on the openelec-6.0 branch if that's what you mean. In other words, it has Kodi Isengard (15.1 IIRC). I've been running something close to that on mine for awhile now without major issues.
                            If you mean that you want Kodi Jarvis (16), that's not tagged yet by OpenELEC. It's only available on their master branch.
                            I just started building off their master branch, and will post a (probably semi-broken) release of it on this thread shortly if anyone wants to test out Jarvis. It's still entirely based on kszaq's awesome work.
                            Also, I'm curious how the amlinux release was working better if you're able to explain.
                              For me is important: has newer tvheadend client, and not stuttering when I playback recorded hd tvshows.
                              In kszaq release I can't update tvheadend client addon to newer, because don't find.
                              And maybe the newer kernel has some advantages at playback quality
                                Thank you envagyok, I'll need to check it out.
                                Regarding tvheadend, an older version is only available in the OE unofficial addons repo. You can grab new versions from http://build.mycvh.de/Tvh/ and install as an addon (System -> Add ons -> Install from zip file). tvheadend is not built in with OE by default.
                                Edit: regarding stuttering, I think it might be that the kszaq release you ran was missing the 23.97fps stutter fix.
