[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by Dc0de View Post
You may want to open one and look for a version number on the mainboard, and post here. There are lots of different ALL BLACK MXQ's (see my posts above)
There is currently one list in 4PDA, but it seems outdated/incomplete.
For instance, my board is labeled as S805_MXQ_V2.0_150415, which is not listed. Kszaq's HD18Q build works fine in my box except for the LED.
Originally posted by Wendigo View Post
I actually think that it would be a great idea to have a comprehensive list of HD18Q versions, with what is working/not working for each one, link to stock ROM if available, etc.
There is currently one http://4pda.ru/forum/index.php?showtopic=621980&st=1340#entry42704536&q uot;]list in 4PDA[/URL], but it seems outdated/incomplete.
Im starting a new thread at the moment. Hold Tight...Will post a link to it when done
EDIT: Thread now live. Please help by posting on that thread about ALL BLACK MXQ http://freaktab.com/forum/tv-player-...ones-directory
Lets leave this thread to Openelec only.Last edited by Dc0de; 30 November 2015, 20:11.
Originally posted by Centurione_01 View Post
@TheRealJohnGalt
I was wondering if one of this builds could work to update my SD card installation on MK808B plus.
At the moment I have not an available SD card to make experiment (I will buy tomorrow), but if it will not work, how difficult are the modification for MK808B plus starting from MXQ. It seems to me that the 2 platform are not so different, I could try to do if someone can point me to some article to build the toolchain (in Ubuntu).
Thanks for all the work and all the interesting reading.
At the moment it seems to work correctly.
Thank you very much.
Hi I tested the build, and they do not work with MK808B plus, so I imported your git project and I compiled it for MK808B plus.
TheRealJohnGalt The russian build is based on https://github.com/surkovalex/OpenEL...e/openelec-6.0 as far as i can see.
flashed an all black mxq with hdq18 (realjohn version)like ive done several times before worked fine remote and wifi didnt work so flashed with the mxq one everything appeared to work fine wifi connected but when i got to add soursec says its not connected but it actually is anyone come across this
Centurione_01 +1 on this: please share the MK808B plus build, we want to try it too!
TheRealJohnGalt First, thanks for you hard work! Second, my only issue is the following: I execute Openelec via microsd card, device attached on the tv via hdmi, optical cable from tv to the 5.1 system (philips fidelio HTL9100, capable of AC3 & DTS decoding), passthrough checked in openelec. It decodes all the surround channels perfectly when the codec is AC3, but when the content is encoded in DTS I have to uncheck the option in order to be able to reproduce it (obviously in stereo). Hope the new version could fix this behaviour, anyway thanks for your effort!
@TheRealJohnGalt Thanks for the builds! Your HD18Q build is working fine on flash for an OTT MXQ Box with black lettering on top:
One question: when i power off the box, the blue led stays on, and i will never go off. Any chance of fixing this? Or Maybe an option to disable the led, that would be even better!
Thanks in advance! I would build the image myself if i could but i don't have the experience to make an image
Originally posted by Bombone View Post
I tested it updating kszaq 5.95.5.2 SD card installation.
As always, as a disclaimer, I am not responsible for anything bad could happen to your MK808B plus, do any update at your own risk
TheRealJohnGalt thx for your work
I'm testing (on sdcard) your MXQ rom (OpenELEC-Amlogic.MXQ.arm-6.0-devel-20151127163356-r21676-gb9749b3) on my S85 box, it seems to run fine, much snapier than other roms i've tested so far.
But there's something i can't make to work, i'd like to override some keymaps to remove the ShutDown() on power button but putting my xml in /storage/.kodi/userdata/keymaps/ doesn't seem to work.
Has something changed in OE6 ? Sorry it's not really a rom feedback, i'm also looking openelec forums for an answer..
Centurione_01 many many thanks, you're the best manI'll try your build asap and report the results!
There are currently 2913 users online. 1 members and 2912 guests.
