Do you think it is possibile to overclock GPU and CPU?
[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Kostaman
Sorry for not being very specific. It says MKV S805 on box but under android it says MKV S805P, Android version 4.4.2, and Kernel version 3.10.33. I extracted the image file and then restored the disk image using the Ubuntu disk utility. And the aml_auto script file, kernel, and system files are on the sd card after the process was completed. I then put the sd card in the MKV S805 and press and hold the button under the box to enter android recovery and press the power button. The blue light comes on and then Amlogic S805 Mali 4 Core square box grapic comes up on the screen for a split second and then the box light turns red like its been powered off or put into standby mode. Even if I don't press and hold the recovery button it still does this.
To install the openelec, you have to remove power cord, press and hold the button under the box, and plug the power cord. Just pressing the power button is not enough. In case it does not work, repeat the process holding both buttons (reset button under the box and power button in top of the box). I hope it helps..
Does the AV port supposed to work in openelec? I have it working in Android with this problem box http://freaktab.com/forum/tv-player-...-logs-attached
Originally posted by Dc0de View PostDoes the AV port supposed to work in openelec? I have it working in Android with this problem box http://freaktab.com/forum/tv-player-...-logs-attached
Running MXQ.arm-6.95.2.2-devel-20160418205554-r22629-ge6fa0b4 from Nand on all black MXQ, board number: 'AM_MXQ_A 20150825
mwp1,
Okay I held the power button and reset button and then plugged in the power and it booted openelec off the SD card. However as soon as I released the power button it turned off. I tried it a few more times but it wouldn't finish booting the sd card into openelec. It would just keep reloading the Isingard graphic on the screen and as soon as I release the power button it shuts off completely. Am I pressing and holding the power button for to long? Also, do you only have to do this once or do you always have to start it up that way to boot the SD card with openlec on it?
I believe this is an issue with your box. see link above.
Originally posted by Jiffypop View PostKostaman,
So you think I should downgrade/flash the current android version? I have already downloaded the older version of android in that post. If you think thats what I should do then how do I flash the older version of android to the MKV?.
Originally posted by kszaq View Post
Anyway, I tested it, and it didn't work. Still the same, more or less... Buffering, or CEC not recognized....
Originally posted by Jiffypop View PostKostaman and mwp1
I forgot to mention that the older android firmware that I downloaded wasn't in a zip format it was in a rar format. So, It doesn't recognize the file when I am in android recovery..
Originally posted by peppearci View PostTested, dirty flash from update file, openelec mxq build on nand. CEC and suspend works fine for me!
Why would you need to overclock CPU in OE?
Originally posted by mwp1 View PostHello kszaq. Don't worry, I totally understand it. I can just thank you for trying.
Like Guest said - no support for AV output in my builds.
Thanks for checking. One question: have you tried doing a hard reboot (unplug power) after installing the test build?.
There are currently 1291 users online. 2 members and 1289 guests.
