[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by peppearci View Post
My mxq seems sluggish and unresponsive sometimes, no plugins installed except iptv simple client
I have no plans to introduce that change in my builds as I don't want people to fry their boxes. For overclocking you need a decent heatsink, like in ODROID-C1+:
Originally posted by kamacnik1 View Posthttp://m.tomtop.com/HD18Q-Smart-TV-B...TT-EDM-EDM0418
Kszag - is Your ROM compatible with this box ?
Price is very good, but not for long time
No one has ever got a bargain on these boxes they're around £24 and that's the bottom line, cheaper and you take a big risk of buying crap!
Originally posted by kszaq View PostS805 can be overclocked to 1.7GHz per core: https://github.com/hardkernel/linux/...989c6de1493658
Since I have decent heatsinks on my mk808b+ ...
Is there a way to add these myself? Or do I need to change the code and then compile everything? (No real skills in programming yet ...)
I have red light on my mxq v3_1 20151230 I can get blue light to come on using certain roms but they don't work. When I take out sd it goes back to red light. I have tried openelec and twrp I get blue light with the openelec and red with the twrp. I get errors on usb burner. I used an image file from one of the forums here and I got my box back up and running and i tried anotherone and I got red light. If anyone can please help a noob out and Point me in the direction of a good file to use I would really appreciate it. Thanks
Is there a way to add these myself? Or do I need to change the code and then compile everything? (No real skills in programming yet ...)if you could provide us some more infos it would be great! also pm!
Originally posted by Warth7 View PostI have red light on my mxq v3_1 20151230 I can get blue light to come on using certain roms but they don't work. When I take out sd it goes back to red light. I have tried openelec and twrp I get blue light with the openelec and red with the twrp. I get errors on usb burner. I used an image file from one of the forums here and I got my box back up and running and i tried anotherone and I got red light. If anyone can please help a noob out and Point me in the direction of a good file to use I would really appreciate it. ThanksAll Black MXQ
Working OpenELEC -OpenELEC-Amlogic.m201d.arm-6.95.2.2-devel-20160419155042-r22630-g8a99467.img.xz On SD
Working Android img - cyx_MXQ_8189etv_8g1g_kodi_addons_160126_SD升级.rar
Board Number: MXQ S805 V3_1 20151230
kszaq Sorry I haven't got back sooner, been rather busy! Currently testing version in footer will try and give feedback by the end of today. Seems OK and suspend is back to being snappy after last Devel build from the 18th where it seemed to pause but did work. Will check vid playback and time updating from resume later.
Running MXQ.arm-6.95.2.2-devel-20160419155328-r22630-g8a99467 from Nand on all black MXQ, board number: 'AM_MXQ_A 20150825
Originally posted by kiwi_man82 View Post
So you still haven't managed to get you box to work again? You have tried using the same android fw as me correct? (Not trying to be a smart ass) Because what you are saying about your box sounds very similar to the problems I was having with my box until I got the cyx fw to flash. Hope you get it sorted mate because I know how annoying it is to be in your situation ✌
Originally posted by Jiffypop View Postmwp1,
Okay I have ubuntu on my computer so I will try and use a laptop with Win 7 on it so I can use Amlogic USB Burning Tool. So you don't think that my version of Android being newer is the problem or you do?
Hello Jiffypop
I don't think the newer android version you have in your box is the problem, but if you want to try the version I am using, I suggest you first backup your version of Android using TWRP.
Instructions for MXV S805 :
You can use TWRP from this link (use TV-110 twrp recovery, it works perfectly for me):
The android version I am using is from this link, and the date of the firmware is 2015-12-28:
Now, to update the firmware, you can follow the tutorial from this link (you will need a USB A-male to A-male cable, I made one myself using 2 old mouses USB cables):
Note: I used a newer version of the Amlogic burning tool, from this link:
Now, for the openelec, when you save the OpenELEC image in the SDcard (using Win32DiskImager or some other tool for Ubuntu), you should see in your SDcard a partition of 512M with 3 files: aml_autoscript, KERNEL.IMG and SYSTEM
Then you just need to place the SD card in your MXV box, press the button under the box and energize the box. You should see the recovery Android robot with a progress bar, and after that the system should reboot in OpenElec.
Good luck. Tell me the results that you got..
There are currently 3817 users online. 1 members and 3816 guests.
