I do recall a while ago i had this hanging issue which was caused by an addon.
Go to Systems/Addons/System/Running
See what is running. If you have a build with loads of addons it will be hard to identify which running process is the culprit.
As an example i only have 7 processes running and only 2 of them are used by Video addons.
The rest are skin helper, openelec configuration , Super Favourites, etc
__________________________________________________ ______________________________
All Black MXQ:Running OE-Amlogic.MXQ.arm-6.95.2.2 On Nand. Board Number: AM_MXQ_A 20150825
