[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by kszaq View PostI'll continue providing support in this thread, although a preferred forum would be LE forum. I also plan to support LE builds directly and backport fixes to OE releases for those who want to stick to OE.
What's LE? I tried looking it up can't find nothing on it. Don't leave us my friend!!!
hi to all
K thx for all your work, have allready registerd to LE forum and looking to it
a qustion to all u that have all black mxq with bord am_mxq_a 20150825
im running OE from nand(6.95.1.3) for some time now, and i have a little issue with kodi crash from time to time
it happens every day.
does it happen to u too????
it happens the most when i brows the skin shortcuts(using fenomenal skin) when i press the return button kodi freezes and restarts(i see the splash screen of kodi)
it was worse in the OE 6 builds , there kodi would just freeze and i had to unplug the power manualy.
have just made a new cleen istall of every thing just incase.....
Running MXQ.arm-6.95.2.2-devel-20160419155328-r22630-g8a99467 from Nand on all black MXQ, board number: 'AM_MXQ_A 20150825
Be very careful with skins as there has been an upgrade in the filing system with skins in Jarvis 16 and not all skins are working properly.
Maybe upgrade and see if confluence is freezing. Then install the skin fresh. Is the skin in official repo ??
If not you have to be careful with versions installed.
__________________________________________________ ______________________________
All Black MXQ:Running OE-Amlogic.MXQ.arm-6.95.2.2 On Nand. Board Number: AM_MXQ_A 20150825
Originally posted by kostaman View PostI have your Board and so does Guest however i have no freezing or hanging. I am however running a different version of OpenElec see footer.
Yes the skin im using is from the official repo (phenomenal).
Now I'm trying not to use many shortcuts in my home screen (problem for the kids)
I posted two new builds:
6.0.3.7 with updates from 7.0 branch.
6.95.2.3 with the following changes:- fixes for command buffering and general fixes in new CEC driver
- m201_1G device tree for HD18Q builds
- reverted some Kodi patches to fix video/audio sync issues
- removed recovery.img from NAND installation zips for better compatibility
- added support for boards with 512MB RAM (m201d build)
- added am_net2818 module to fix Ethernet not present when using custom device tree
What happens now? While waiting for your feedback on the new build, I'm cooking my first LibreELEC release. I'll be providing you with 7.0 releases, no master branch snapshots (like it's been with OE builds). I'll update my OE release to 7.0 when it comes out. When I implement an Amlogic-specific fix for LibreELEC, it'll be included in OE build but my main focus is on LibreELEC now. As far as I know, you can update from OE to LE without losing your current setup.
There are currently 2759 users online. 0 members and 2759 guests.
