[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by kszaq View Postbordiart Here's a workaround for box not detecting refresh rates: http://s805.eu/utils/disp_cap_hack/
It works with all my releases.Last edited by bordiart; 15 April 2016, 08:26.
Originally posted by kostaman View Postkiwi_man82 In Android you could try app: https://play.google.com/store/apps/d..._advance&hl=en
See what that brings up.
By the way have you opened this box and seen what ram is physically inside.All Black MXQ
Working OpenELEC -OpenELEC-Amlogic.m201d.arm-6.95.2.2-devel-20160419155042-r22630-g8a99467.img.xz On SD
Working Android img - cyx_MXQ_8189etv_8g1g_kodi_addons_160126_SD升级.rar
Board Number: MXQ S805 V3_1 20151230
Originally posted by kszaq View Postkiwi_man82 fanni2 I made a small test: I installed cyx firmware on my box and ran "free" command... Guess what? My box also has 2GB of RAM!
Not really. Cyx firmware fakes RAM amount and your boxes have only 512MB of RAM. Confirmed by device tree. It does not lie. I will compile a "m201d" build for these boxes with a proper device tree. OE is much less RAM hungry and it should run fine with 512MB.All Black MXQ
Originally posted by kiwi_man82 View Post
So even with 2x512meg ram chips I should only have 512meg but more grunt? Maybe they are connected in parallel? And Like batteries when connected in parallel it doesn't increase the voltage the batteries supply but provides more amperage? 😂😂😂 haha.
Cyx firmware adds 512MB swap and that sums up to 1GB total memory, that's why you see more than 512MB total.
Remember that chip markings are in megabits and not megabytes. There is also a multiplier on them. For example, my box has 2 chips with 256X16DDR3 markings which sum up to 8192 megabits = 1024 megabytes.
Cyx firmware adds 512MB swap and that sums up to 1GB total memory, that's why you see more than 512MB total.All Black MXQ
Oh right, I did not know that. So 512x8ddr3 chips means it is 512megabits x8? 4096 megabits? Which is 512 megabytes? I'm confused still... I'm not doubting you so please don't think I am. Just trying to learn a bit more and understand some more technical stuff than I do atm. So is it false advertising then to sell it as a 1gig ram device because I would expect it to have 1gig physical ram, not 512 meg with 512 swap?- cyx firmware fakes RAM amount visible to user and adds 512MB swap - tested on my own box (HTC-MXQ-V4 board with 1GB physical RAM)
- device tree in cyx firmware defines there is 512MB physical RAM
Yes, 4096 megabits is 512 megabytes. Here's what I know for sure- cyx firmware fakes RAM amount visible to user and adds 512MB swap - tested on my own box (HTC-MXQ-V4 board with 1GB physical RAM)
All Black MXQ
Originally posted by kiwi_man82 View PostOk. One more question for you there, why does cpu z show 1gig but free cmd in terminal show 2gig?
burimek To get back the old CEC buttons behaviour, please use this (instructions inside): http://s805.eu/utils/old_cec_keymap_for_new_driver/
Originally posted by kszaq View PostMaybe it shows physical RAM + swap. Or there's some other trickery going on. This is all with 20160116 firmware, right? I stress that these are all my assumptions, I don't know for sure.
Guest To get back the old CEC buttons behaviour, please use this (instructions inside): http://s805.eu/utils/old_cec_keymap_for_new_driver/All Black MXQ
kszaq
I just did some extensive testing of the new CEC driver in 6.0.3.6 and it is really nice. It fixes an issue that I had with the old CEC driver where :
When switching between active HDMI inputs (PS4) and (MK808B plus) on my Panasonic TC-P50GT25 TV, CEC control would be lost when switching back to Openelec. This is actually fixed in the new driver!!!
Thanks so much...again!
Please stick with the new driver going forward. It is the best.
sammaz The new CEC driver is actually Gerald's work, I only fixed it a little bit.
A new build ready to test:- for V3_1 board users, there is a new target: m201d - I included remote.conf from factory firmware, please let me know if there are any buttons that don't work. Please remember to delete remote.conf from Configfiles folder first if you have put one there. Device tree is almost the same as cyx firmware, therefore 512MB RAM is available. NAND installation should work wihtout modifications now.
- mwp1 kostaman please test CEC in this build - does it work and how it behaves after suspend/wakeup?
- JoeyDaPhish Can you check if this build fixes audio sync for you?
Originally posted by kszaq View Postsammaz The new CEC driver is actually Gerald's work, I only fixed it a little bit.
Installing to nand gives the following error
A new build ready to test:- JoeyDaPhish Can you check if this build fixes audio sync for you?
There are currently 3634 users online. 0 members and 3634 guests.
