[ROM] Unofficial OpenELEC for MK808B+ and MXQ
VictorDUA Read my post http://freaktab.com/forum/tv-player-...642#post566642
Don't worry about the lights. There is a lot written in previous posts about the sequence of the LED. It is the way the GPIO pins are wired and the Bootloader Blah Blah Blah.
It is not a problem.
If you do a re boot the Blue light will be on when the box is on.
If you turn it off it will stay Blue. Then turn it ON and it will go Red. Same as mine and a lot of others.
Can you please write a footer on your Box / Board / OpenELEC Version including whether you are on NAND or SD Version(Android boot to SD)
When you post.
It really helps us Help You.
__________________________________________________ ______________________________
All Black MXQ: Running MXQ.arm-6.95.2.1 On Nand. Board Number: AM_MXQ_A 20150825
Originally posted by nigelg View Post4) Ticker still doesn't work, but you haven't said that you fixed it so I expect you knew that!
Thanks.
Actually now CEC has default OE button assignement. I think this can be changed somehow, I'm not sure how.
Originally posted by kiwi_man82 View PostHave just tried sd boot of oe 6.95.2.2 with your new kernel.img but it hangs at mxq splash screen
@bodiart Back to not being able to select 50Hz - I noticed that one of my boxes does the same. It looks like it has a hardware flaw that prevents some HDMI signals from passing through - in result there are CEC issues and I'm not able to select anything but 60Hz, just like you! I have a possible workaround in mind, I'll test it when I have some free time.
Originally posted by mwp1 View PostI have tried build 6.95.2.2, and CEC is still not good. Sometimes it happens command buffering, sometimes it is not recognized by TV. After suspend, cec stopped working. I tried the test kernel, and cec didnt work at all.
Thanks.
@all: From now on I will be posting test builds from time to time until we agree that everything works.
Originally posted by kszaq View Post@bodiart Back to not being able to select 50Hz - I noticed that one of my boxes does the same. It looks like it has a hardware flaw that prevents some HDMI signals from passing through - in result there are CEC issues and I'm not able to select anything but 60Hz, just like you! I have a possible workaround in mind, I'll test it when I have some free time.
Truly hope that you can fix that, that issue makes me upset as I use to watch iptv, which is 50fps. I am glad that the issue is reproduced. Thanks in advance.
thanks for the new version but i have big problem with this new one on mxq, my tv remote have no more acces to menu buton with blue tast. i have before this version with my tv remote cec acces to menu?
, in earlier version in my tv remote , i have context menu in blue tast, now with this version jarvis my blue buton get another function, i precise that in the original remote MXQ all is ok.
how can i remap this button with keymap, its realy difficult, that is tv remote.
kszaq
if you can fix that like earlier version, thx, without this function, i must use the original remote
Originally posted by kszaq View Postburimek I noticed the colour keys bug after some testing and I figured out that OpenELEC introduced mappings for that keys that override our previous mappings. I fixed this for the next release, aiming for this week.
In the meantime I will be able to test only for MK808B+ as my second MXQ has broken down and I am waiting for a replacement. No luck with these boxes.
Originally posted by burimek View Postthanks for the new version but i have big problem with this new one on mxq, my tv remote have no more acces to menu buton with blue tast. i have before this version with my tv remote cec acces to menu?
kszaq
For the new driver, you can remap your keys with this addon: http://mirrors.xbmc.org/addons/helix/script.keymap/Last edited by kszaq; 13 April 2016, 11:03.
Originally posted by mwp1 View PostThanks kszaq!
Just one doubt. With this new CEC driver, is the command fw_setenv cecconfig still working? It is described in the release page, and I used this command (not sure if was cecb or cec0) in some previous version.
Here's fun fact: I disassembled "cyx-..." firmware that you posted and device tree defines that there's only 512MB RAM in your box... Can you please run terminal emulator in Android and show me result of free command?
All black OTT MXQ 6.95.2.2 "power off" works strange.
When I press "Shutdown", after the pause around 5 seconds my skin reloads
I press "Shutdown" second time and sometimes skin reloads second time and sometimes MXQ shuts down.
Just now first and second "shutdown" just reload skin after the pause and only third time shots MXQ.
Thanx.
Originally posted by kszaq View Postfanni2 bordiart kostaman As 6.95.2.2 I analysed factory firmware posted on this forum and I have another kernel version to test. Instructions as before:- rename kernel.img on your SD card to something else, like kernel.img.bak
- download the new kernel and put on on SD card
- put SD card back to the box and test!
If it does not work, simply delete the newly downloaded kernel and rename the old one back to kernel.img.
Link to test kernel: http://s805.eu/test/6.95.2.2-m201d-test01/kernel.img
free command output under Android:
total used free shared buffers
Mem: 854016 352268 501748 0 2860
-/+ buffers: 349408 504608
Swap: 511996 77004 434992
There are currently 2547 users online. 1 members and 2546 guests.
