[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by kszaq View PostIf you can't select 50Hz it means that your box thinks your display is not capable of displaying 50Hz. This can't be overridden, unfortunately.
512MB of RAM used... seems like these board have f*cked up u-boot. Let's see if I can solve that somehow by playing with device tree. Again.
Try deleting recovery.img from SD card before using toothpick method.
By the way I installed 6.0.3.1
Let's try a new build, shall we?
6.95.2.2: https://github.com/kszaq/OpenELEC.tv/releases/6.95.2.2
fanni2 kiwi_man82 Please report if this build boots for you. If it does, it should use whole 1GB of RAM (only 796MB is reported in Kodi, that's how it should be).
pesh Try if this one boots for you.
mwp1 kostaman Please try a little bit improved CEC implementation: does it work for you fine after waking the box up from suspend?
Guest Guest Please report if this build boots for you. If it does, it should use whole 1GB of RAM (only 796MB is reported in Kodi, that's how it should be).
Guest Try if this one boots for you.
Guest Guest Please try a little bit improved CEC implementation: does it work for you fine after waking the box up from suspend?All Black MXQ
Working OpenELEC -OpenELEC-Amlogic.m201d.arm-6.95.2.2-devel-20160419155042-r22630-g8a99467.img.xz On SD
Working Android img - cyx_MXQ_8189etv_8g1g_kodi_addons_160126_SD升级.rar
Board Number: MXQ S805 V3_1 20151230
SD card also refuses to boot just stays on mxq logo
Just want to point out that trying to boot from the sd card sem bricks the box as well after removing the sd the box refuses to boot this is for the V3_1 boardLast edited by fanni2; 12 April 2016, 17:20.
Originally posted by fanni2 View PostYes just stick the remote.config file onto the configs folder and then reboot the box remote should now work
Just checking though you do have the same remote that i posted a picture of though as that config file is for that one onlycopy and paste it in the config folder and reboot it just like u said.
Have flashed the new build to the nand but it just hangs on the mxq logo once installed.
fanni2 bordiart kostaman As 6.95.2.2 I analysed factory firmware posted on this forum and I have another kernel version to test. Instructions as before:- rename kernel.img on your SD card to something else, like kernel.img.bak
- download the new kernel and put on on SD card
- put SD card back to the box and test!
Link to test kernel: http://s805.eu/test/6.95.2.2-m201d-test01/kernel.img
Originally posted by kszaq View Postnigelg Thanks for sharing your observations.
1) I admit that "power off" may be unreliable in a few latest releases, I decided to bring back the old behaviour for my next builds. You'd still be able to force the box to "power off" via command line. This would also fix blue screen bug after powering off.
2) Yes, different button assignments are due to new CEC driver. Actually there are in line with OE builds for other devices.
3) That I never experienced. If I can't reproduce, I'm unlikely to fix, sorry.
4) Will look at that and fix.
kszaq Thanks for your reply. I am now running 6.95.2.2 on my MK808B Plus.
1) "Power off system" now seems to be fine. Don't know what you mean by the blue screen bug.
2) CEC seems fine so far.
3) I have had the audio problem once so far, so it's still there, but I fully understand that you can't fix it if you can't recreate it.
4) Ticker still doesn't work, but you haven't said that you fixed it so I expect you knew that!
Thanks.
i just installed it on my MXQ box 18Q board, showing 796MB memory, 20% used and 639MB available
CPU temperature is around 62 degrees C
static ip settings still seem to work, just like my VPN stuff
ill do some more testing over the week
thnx for the awesome openelec again !Home Cinema Setup Livingroom:
50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
Bedroom Media Setup:
32" Philips LCD - KR-42 wasser rom
Originally posted by kszaq View Postfanni2 bordiart kostaman As 6.95.2.2 I analysed factory firmware posted on this forum and I have another kernel version to test. Instructions as before:- rename kernel.img on your SD card to something else, like kernel.img.bak
Have just tried sd boot of oe 6.95.2.2 with your new kernel.img but it hangs at mxq splash screenAll Black MXQ
Thanks..
[QUOTE][ Originally posted by kszaq View Post
QUOTE]
Originally posted by mwp1 View Post
I have tried build 6.95.2.2, and CEC is still not good. Sometimes it happens command buffering, sometimes it is not recognized by TV. After suspend, cec stopped working. I tried the test kernel, and cec didnt work at all.
Thanks.
Using my TV remote the only benefit is i can Pause/Stop/Ffw/Rw/Navigate GUI Without bringing up OSD.
I can also say that BLUE LIGHT comes ON when i turn Off the box
And RED light comes on when i Turn ON the box. Basically the reverse of the Android OS.
I have POWER OFF/REBOOT/SUSPEND Working with this version.
__________________________________________________ ______________________________
All Black MXQ: Running MXQ.arm-6.95.2.1 On Nand. Board Number: AM_MXQ_A 20150825
There are currently 3823 users online. 1 members and 3822 guests.
