I dont use suspend. I dont like the TV to be powered ON or OFF with the box.
Using my TV remote the only benefit is i can Pause/Stop/Ffw/Rw/Navigate GUI Without bringing up OSD.
I have POWER OFF/REBOOT/SUSPEND Working with this version.
mwp1 Please note if you reboot the box and tv does not respond to commands,
Turn TV power off and turn TV back on. It will work again.
This is with my settings of course as my box does not turn off when the TV turns off and vice versa.
I can help with further testing if required even though i have it working perfectly except with suspend issue which i don't use.
Sharp Aquos Quatron 70 Inch 3 Years old used to for testing
__________________________________________________ ______________________________
All Black MXQ: Running MXQ.arm-6.95.2.1 On Nand. Board Number: AM_MXQ_A 20150825
