[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by Warth7 View Postis there a uboot for the OE builds, i use tooth pick and nothing just black screenAll Black MXQ
Working OpenELEC -OpenELEC-Amlogic.m201d.arm-6.95.2.2-devel-20160419155042-r22630-g8a99467.img.xz On SD
Working Android img - cyx_MXQ_8189etv_8g1g_kodi_addons_160126_SD升级.rar
Board Number: MXQ S805 V3_1 20151230
Originally posted by kiwi_man82 View PostYou want me to collect logs for 6.0.3.1 is that correct? Even thou it is booting and running good? Or did you want me to try another build and collect logs on that?
Originally posted by mwp1 View PostHello kszaq. Just to refresh this subject. Could you take a look at this CEC problem? I collected a log after performing these commands. Thanks!
kszaq Can you bring in this peripheral driver in your next build? I think this will give us full gamepad navigation support within openelec.
[19:09:47 330][HUB1-1][Inf]--Connect path=USB xHCI Compliant Host Controller/P0/P0
[19:09:47 330][HUB1-1][Inf]--Start burning...
[19:09:47 393][HUB1-1][Inf]--------------ERASE BOOTLOADER------------
[19:09:47 393][HUB1-1][Inf]--0-7-0-16
[19:09:47 393][HUB1-1][Inf]--Identify status success
[19:09:47 393][HUB1-1][Inf]-- low_power
[19:09:47 393][HUB1-1][Inf]--Low power command success
[19:09:47 393][HUB1-1][Inf]--Read low power success
[19:09:47 393][HUB1-1][Inf]--bootloader_is_old
[19:09:47 393][HUB1-1][Inf]--Bootloader command success
[19:09:47 408][HUB1-1][Err]--failed: bootloader is new
[19:09:47 408][HUB1-1][Inf]--Bootloader is new
[19:09:47 408][HUB1-1][Inf]-------------Download DDR.USB-----------
[19:09:50 410][HUB1-1][Inf]--Close device handle 0x00000228
[19:09:50 472][HUB1-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&2b642b22&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000228
[19:09:50 535][HUB1-1][Inf]--0-7-0-16
[19:09:50 535][HUB1-1][Inf]--No need download
[19:09:50 535][HUB1-1][Inf]-------------Download UBOOT_COMP.USB-----------
[19:09:50 535][HUB1-1][Inf]-- low_power
[19:09:50 535][HUB1-1][Inf]--Send command success
[19:09:50 535][HUB1-1][Inf]--Read command status success
[19:09:50 535][HUB1-1][Inf]-------------ERASE FLASH-----------
[19:09:50 535][HUB1-1][Inf]--disk_initial 1
[19:11:50 550][HUB1-1][Err]--usbReadFile len=512, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
[19:11:50 550][HUB1-1][Err]--Check command return failed
[19:11:50 550][HUB1-1][Inf]--Failure : 1, FailureMax : 3
[19:11:51 066][HUB1-1][Err]--[19:11:51 066][HUB1-1][Inf]--Failure : 2, FailureMax : 3
[19:11:51 582][HUB1-1][Err]--[19:11:51 582][HUB1-1][Inf]--Failure : 3, FailureMax : 3
[19:11:51 660][HUB1-1][Err]--[0x30201006]UBOOT/Disk initialize/Send command/Time out
Originally posted by PatrickJB View Postkostaman Couldn't get the backup to install but 6.95.1.1 was still juddering occasionally even without addons and a clean install so I thought I'd try 6.95.1.2, which was actually a test build, and for me it works the best so I'm going to stick with it for a while.
PatrickJB I hope you UNPACKED the ZIP and then used the backup tar file which is inside the zip file ??
You cant just try and restore from the ZIP file. I used the zip file just to compress the backup for less upload and download size.
kszaq As I've said above the video playback is, overall, actually worse on 6.95.1.3. 6.95.1.1 was better but the test build you did, version 6.95.1.2 is the one that currently works best for me as far as video playback is concerned. It's still not perfect but it's the best build so far as far as I can tell (only limited testing for about an hour). Slightly strange as I thought the playback improvements were the same in version 6.95.1.2 (test build) and version 6.95.1.3? I figure there must be something about 6.95.1.3 that is causing playback issues as it's actually worse than any of the previous builds, at least for me!
Hey 6.95.1.2 test build seems to be working really well so I'm not being negative just thought i'd flag up a possible issue that some other users may be experiencing even if they don't realise it, if you know what I mean.
EDIT: and that last comment is not aimed at costaman as I believe that he does have perfect playback.
Running MXQ.arm-6.95.1.2-test-build from Nand on all black MXQ, board number: 'AM_MXQ_A 20150825
Notes: Reverted to 6.95.1.2-test-build from 6.95.1.3 because of judder on video playback.
Originally posted by kszaq View Post
Yes, logs from 6.0.3.1 please. I'd like to see which device tree is picked by your bootloader so that I can include it in future builds.All Black MXQ
Originally posted by Warth7 View PostOk i used the the image file OpenELEC-Amlogic.MXQ.arm-6.0.3.1 I burned the image in the SD card. it will not boot up. dose it matter that my box has this chip sk hynix h27ucg8t2etrAll Black MXQ
I've used the HD18Q build on my device. The MXQ builds are for the devices with the red mx on them. Ours are the all black type which require the HD18Q builds ☺
I use the MXQ Arm Builds All black MXQ and it works perfect. If everyone would supply their Board And Version of OpenELEC at the foot of their post/comment we would have a much easier time helping you.
__________________________________________________ ______________________________
All Black MXQ: Running MXQ.arm-6.95.1.1 On Nand. Board Number: AM_MXQ_A 20150825
Originally posted by kostaman View PostPlease edit your quote regarding MXQ Builds are for the red stripe MXQ Boxes only. This is incorrect as it depends on your Board and remote.
helping you.
That will be on the main Thread post. If the device you have does not work then Post a clear photo of the pcb showing chipsets. If your getting errors you most lickly have loaded wrong softwars before trying software. Yes you will need to un Brick the device. Links to how to will also be posted. 😁Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by Warth7 View Posthow can you tell what openelec you have from the board. I'm still learning this. I know I have mxq v3_2 all black box.
On the footer of my posts or comments you will see my box is all black. Next is what version of OpenELEC I AM RUNNING.(Nand means not off an external SD Card) and last is the Board inside my Box.
I ask everyone with the ALL BLACK Boxes supply this information as there are so many Variations of the ALL BLACK boxes.
As an example my remote control is the same as THE RED STRIPE MXQ's
Warth7
Hi Again
I have just gone through your post history and just realised YOU HAVE A CORRUPT ANDROID Operating system.
Do not try Flashing OpenELEC as you are wasting your time.
You must First find A WORKING ANDROID Operating System for your box before trying anything OpenELEC.
If i find anything i will let you know. In the meantime see link below for HD18Q Android roms.
Dont worry about remote or wifi not working in the roms as once you get the box to successfully boot into Android you can then Flash OpenELEC.
More than likely HD18Q will work as i looked at the remote.
http://mbox.co.za/forum/viewforum.ph...0d02bfa3c9312b
There are currently 2462 users online. 2 members and 2460 guests.
