systemctl stop kodi rm -rf /storage/.kodi/userdata/peripheral_data reboot
[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by mwp1 View PostCode:Originally posted by phinc View Post
Originally posted by kszaq View PostI just tried a clean install of 6.0.3.6 and have no problems this menu. Can you try executing commands I listed above? This will reset libcec settings and reboot. Maybe you have some remainings of old settings..
Originally posted by kszaq View PostIs your HD18Q visible in CEC devices list in your TV or it can't be detected at all? Do you have any other devices running OpenELEC (e.g. RPi) and can test whether CEC works on them? Also, try to execture the following commands over SSH:Code:systemctl stop kodi rm -rf /storage/.kodi/userdata/peripheral_data reboot
When I execute these commands over SSH, the CEC is briefly recognized by the TV, but then the KODI interface returns the language alone to English (I use Portuguese), and TV does not recognize the unit anymore..
Hi Kszaq and every 1
Need some help with some sound problems
I'm connected with HDMI to my tv. From the tv (headphone output) a 3.55 cable to the Samsung sound system to the aux input.
I'm trying to use the analog or the spdi f outputs of the MXQ with no success.
Connected 3.55 cable from analog out of mxq to aux input of the sound system, only 1 speaker works.
Connected a diffrent cable( 3.55 to spdi f a new optical cable) spdi f of the now(with the 3.55 output) to the optical input spdi f of the sound system and no sound.
Tryed the 808b and the hd18q roms and no sound.
I have attached a pic of my bord am_mxq_a 20150825.
Can any 1 tell me where is the audio chip on this bord ??
I'm lost.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
I'm lost.
EDIT: And as you know I have the same board!
EDIT 2: I just thought that your TV may have an optical out on the back if you want digital audio into your amp! The analogue signal will be delayed if you're watching movies!
EDIT 3: Err and I know it's not an optical out on the MXQ, I was just getting confused!
Running MXQ.arm-6.95.1.3 from Nand on all black MXQ, board number: 'AM_MXQ_A 20150825Last edited by PatrickJB; 04 April 2016, 12:58.
Originally posted by PatrickJB View PostYou'll need to use an AV cable for the audio, I did try a regular mini jack with two phonos and I had the same problem. And if the audio decoder is set to analogue I don't think the optical out will work but the HDMI still carries sound as you probably know.
The spdi f really doesn't work no matter what I do.
Somthing strang ...on the mxq when I plug in the A/V cable all the wey in to the analogue out only 1 speaker(of 4 From the sound bar) works, but when it is 3/4 in the mxq analogue out suddenly all works(4 on the sound bar and the sun). U solved my problem.
Audio is set to analogue 2 ch with upmix and all is good.
Why is it like that, I mean does it have a mini Jack out? Am I using wrong cable?
Again it is plugged in 3/4 of the way in and not all the way.
Is it a AV cable with three phonos on the end like this: http://www.amazon.co.uk/Pro-Signal-P...=sr_1_1&sr=8-1
Originally posted by PatrickJB View PostIs it a AV cable with three phonos on the end like this: http://www.amazon.co.uk/Pro-Signal-P...=sr_1_1&sr=8-1
On the other 2 rca connectors
It even works with a 2 sides 3.5mm Jack
Only when I push it 3/4 in and not all the way in.
Strange!!!
Has anyone encountered random network slowness?
When issues are present, pinging my default gateway returns ~1000ms:
Code:OpenELEC:~ # ping 10.0.0.138 PING 10.0.0.138 (10.0.0.138): 56 data bytes 64 bytes from 10.0.0.138: seq=0 ttl=64 time=1037.157 ms 64 bytes from 10.0.0.138: seq=1 ttl=64 time=1011.060 ms 64 bytes from 10.0.0.138: seq=2 ttl=64 time=1101.837 ms
Any idea what could be the problem?
michaelchen As I said a couple of posts back it needs to be a AV cable like this: http://www.****.co.uk/itm/1m-3-5mm-4...IAAOSwvgdW3Ibj Obviously you don't use the yellow connector as thats for the video but the socket is made for this type of jack. Note the image on the **** page!
Originally posted by niros View PostHas anyone encountered random network slowness?
if its that close why not use a cable?
There are currently 1751 users online. 0 members and 1751 guests.
