[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by kostaman View PostI have been creating a backup immediately after a fresh install just as a quick way of creating that directory without typing it in with file manager.
In File Manager I then add it as a source. In File Manager i Then open Backup directory on left side and across to right and open usb and copy file to Backups.
I cant see this as a problem unless you do.
The file is in the right place when i do a restore from previous backup.
Thanks again.
I'm wondering if there's a problem with some addons which is causing other people problems! The other thing I worry about is hard-booting and corrupting the install which I'm sure has happened to me in the past.
Running MXQ.arm-6.95.1.1 from Nand on all black MXQ, board number: 'AM_MXQ_A 20150825
Originally posted by jjbull View Postfollowing your guide i have no log files in the storage(i used winscp on my laptop to access my box) but did find it somewhere else but its not letting me upload it i keep getting invalid file kodi.log
what am i doing wrong
Originally posted by jjbull View Postim not as dumb as im coming across i promise lol
for some reason cant connect over samba can i use kodi log uploader will that work ?
Looks like my remote issue Is now fixed
I use a different remote.conf now and It seems to work
How do I change the function of the mouse button ?
I like to assign "subtitlesearch" to the mouse button
Using this remote.conf: https://tinyurl.com/hdfd5zcYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
kszaq Simple question, is there a way to connect two MXQ's adhoc, possibly other devices, err like my bargain WD Live TV box? I'm worried that I won't have any internet at some point in the future! The WD box is working out well with the MXQ streaming to the WD in my bedroom from BluRay file discs on the MXQ in the living room. I would just use my backup MXQ in the bedroom, yes I have another one after my last experience of deep fried chips (!), but for most files the WD offers superior playback especially as the TV in my bedroom is bigger (42").
I won't mention the CS / ION thing at the mo as we'll see but if it doesn't happen then it might be worth trying the vid playback hacks to see if they have any real effect.
Originally posted by jjbull View Postk mentioned about using the command createlog in console to get my log files over ssh im using winscp can someone explain how i do that
Originally posted by PatrickJB View Postkszaq Simple question, is there a way to connect two MXQ's adhoc, possibly other devices, err like my bargain WD Live TV box? I'm worried that I won't have any internet at some point in the future! The WD box is working out well with the MXQ streaming to the WD in my bedroom from BluRay file discs on the MXQ in the living room. I would just use my backup MXQ in the bedroom, yes I have another one after my last experience of deep fried chips (!), but for most files the WD offers superior playback especially as the TV in my bedroom is bigger (42").
Originally posted by kszaq View PostLike PatrickJB said, Kodi log is not enough when it's about kernel/hardware issues. You can open terminal (command line) in WinSCP in Commands menu. There you can enter createlog command and the log should be ready for you (you may want to refresh folder contents to see it).
PatrickJB Thanks for the footer, it makes things clearer. From the top of my head... the easiest way would be connecting your devices with ethernet cable and setting static IPs. You may also get a cheap router - like Xiaomi for $15 - and make a network without internet connection. I've never tried connecting my devices with ad-hoc network, I don't know f that's easily obtainable in OE...
There are currently 2086 users online. 2 members and 2084 guests.
