I plugged my mini usb Ethernet into the full size usb and it works so then I tried my remote control usb dongle in my otg port and that works to so all is good just using a few adapters but why won't the Ethernet adapters work in the otg port ?
[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Bit of an update on my Ethernet adapter not working in my otg port, I bought a couple of USB adapters to move things around.
Originally posted by michaelchen View PostHi Kszaq and every 1
Need some help with some sound problems
I'm connected with HDMI to my tv. From the tv (headphone output) a 3.55 cable to the Samsung sound system to the aux input.
I'm trying to use the analog or the spdi f outputs of the MXQ with no success.
Connected 3.55 cable from analog out of mxq to aux input of the sound system, only 1 speaker works.
Connected a diffrent cable( 3.55 to spdi f a new optical cable) spdi f of the now(with the 3.55 output) to the optical input spdi f of the sound system and no sound.
Tryed the 808b and the hd18q roms and no sound.
I have attached a pic of my bord am_mxq_a 20150825.
Can any 1 tell me where is the audio chip on this bord ??
I'm lost.
I'm thinking that this is your problem and if it is, I'm sure you'll forgive the direct tone of my post. If you've already tried with the setting changed to S/PDIF, I tried to help but you knew it already. I had to ask tho.
Just checked my Ott mxq box and the spdif output is NOT optical. it's coaxial unlike my red tick beelink mxq. Makes a mockery of my post and provides your answer as you can't connect to an optical input from this box.Last edited by sonofdibnah; 06 April 2016, 08:31.
Originally posted by antiguangenius View Post
signal overlap too close...
if its that close why not use a cable?
I tried using this usb-to-ethernet and indeed latency is much better but speed can only reach 6Mbps which is extremely low.
ethtool reports 100Mbps link:
Code:OpenELEC:~ # ethtool usbnet0 Settings for usbnet0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Speed: 100Mb/s Duplex: Full Port: MII PHYAD: 0 Transceiver: internal Auto-negotiation: on Current message level: 0x00000007 (7) drv probe link Link detected: yes
Originally posted by PatrickJB View PostIs it a AV cable with three phonos on the end like this: http://www.amazon.co.uk/Pro-Signal-P...=sr_1_1&sr=8-1
H MAn
Originally posted by Hercules Man View Post
I thought MXQ used coaxial spdif cable like this http://www.****.co.uk/itm/2m-Gotham-...cAAOSwU9xUQ9-1
H MAn
Running MXQ.arm-6.95.1.3 from Nand on all black MXQ, board number: 'AM_MXQ_A 20150825
Originally posted by sonofdibnah View Post
Reading through this and the later posts about it, you haven't made it clear what you're doing when trying to use S/pdif. PatrickJB has stated that the audio output device setting needs to be set to S/PDIF but you've been a bit vague in your response. So, what setting do you have in System>Audio output>Audio output device when you're trying to use optical S/PDIF?
My mxq spdi f output is not optical, but my sound bar has a spdi f input, so I bout a new cable on the net. One side 3.5 and the other side spdi f.
My audio output settings are aml8/spdi f
No sound at all.
As patrickjb mentioned I need to try a different cable a/v with 3 rca whit red and yellow (analogue on audio settings).
Let me clear a few thing first
No sound at all.
Originally posted by PatrickJB View PostJust remember what I said that the analogue signal will be slightly delayed this could be corrected with the audio offset function under audio and subtitle settings and making it default for all media. Have you tried enabling passthrough for the digital/spdif output? It's on the audio and subtitle settings page with the audio offset. I'm not sure what this really does but it's worth trying.
When I first tried analogue , while plugging the cable there was a noise coming out of the sound bar, but when tried the spdi f output there was no sound at all.
Thx for the tip, will try when I get the cable.
Enabling passthrough meens that the audio decoding will be handled by the amp and not by kodi.
Hi all and michaelchen : I got the Mxq S85 Beelink, my A/V 3.5 output works normally with a Y/R/W old cable from a N95 8GB Nokia phone. It works, also, with the same cable that came with the box (lesser quality, though). I have nevertheless seen many others have problems with non original OEM cables that can easily be solved trying to exchange cables on the input ( e.g. sound bar or amp ) side: if you have only one channel with R and W connected, exchange the not working one with Yellow cable!
Hope this helps!
Regards
Alessandro
Shadi86, I think the opposite to jjbull above and think you should try the mxq version first. Can't speak for the board but I have an mxq all black with the EXACT same remote as yours (coloured buttons immediately below the power button) and that's what I use. I suggest you try running from SD card first because you'll retain android on nand if it doesn't work. That way you can play until you find out if jjbull or me is correct with no risk to the box.
There are currently 1929 users online. 1 members and 1928 guests.
