[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by kszaq View Post
You could also ask for advice on this thread: http://freaktab.com/forum/tv-player-...-tv110-mx2-g18
Considering how K. has made things more and more "simple", starting from .uenv and aml.autoscript, which were also known techniques ( but implemented widely by nobody until K. started), I want to point out that in Amlinux for S905 we now have a .dtb image file which can be switched to adapt different ram/rom and chipset configuration within certain limits, to a fixed OE Release! I do not know at all if this could also be done in the ( vast really ) builds that K. maintains , but I see all this as a real turn towards a certain multiSoc scalability and an easier approach to compile a Sw, which in the end can be adapted to different devices. Modularity? Or I am getting it wrong and this is possible only with Amlogic processors architecture? Btw, I am thinking philosophy, because I can't think in the programming way!
Regards
Wonderful work, kudos kszaq !
Alessandro
Originally posted by jekkos View PostHello all,
I'm facing some weird problems with my AM_MXQ_A board (rlt 8189ETV chip). All was running wel with 6.0.1.2 and all of a sudden the board stopped booting. I attached a serial console and found that the bootup stalled after the bootloader started the kernel. As I didn't change anything I thought this was pretty weird and tried to reflash. Device boots up from sd after toothpick and flashes new version to nand. But after reboot it stalls at this line
I was able to reflash original stock android rom which does work!! But once I want to go back to OpenElec the board stalls on on this line. Anybody got any idea what could be wrong here? Maybe a hardware issues or bad flash block or something? So no problem to boot into recovery or into original Android ROM, it's just that none of kszzaq's (nand, sd) builds work any longer, I've tried all recent version to no avail (even 6.0.3.1)
I could try to boot into uboot and load kernel on different address (not from nand) but no idea how to boot further. One thing I did notice is that the address of timer changes from boot to boot. Not sure whether this is normal or not.
Could be a nice tip for other people facing weird and unseen issues!!
Also good to know is that once you have serial connection then usb burning becomes a breeze as there is a standard command in uboot to enable OTG mode for flashing using amloigc tools in windows. In this case you don't need to short nand pins and possibly damage your circuit board!!
I also flashed another bootloader and now even my led is turning colors. This wasn't even working with the original stock rom!! Not sure how they develop this software in the factory but looks like some binaries were reused or something. Only funny thing is that the led doesn't go off, it changes to red once I suspend and stays red next time I resume.
kszaq any idea if this led issue is something linux or uboot related? I guess it's a combination as the rom is the same but now it turns red due to different uboot. Also really nice that wifi works when resuming the system now!! It's fully functional and I'm a happy camper now.
Kszaq,
Thanks for your hard work
Just an observation/question to the latest MXQ 6.0.3.5. version NAND. I have a Beelink "red" MXQ which had 6.0.3.2. on it. I updated my box with tar files from the original zip version of 5.0.8.20. Everytime the Kodi "Power off system" worked and the LED on the box changed from blue to red.
Now I updated the box to 6.0.3.5. version using tar file, and now when I "power off system" the LED is not changing, but looks like the box powers off. If I use "Suspend" instead of "Power off system" the LED changes from blue to red.
Can you pleae look into it. Otherwise the version looks good to me.
Thanks, Arpad
My remote stops working on the MXQ s805 ott box (all black)
Running 6.0.3.5 on NAND MXQ s805 ott box (all black)
Copy remote.conf to \Configfiles\ and reboot, now the remote works perfect
When I unplug the powercable for lets say 1 minute and plug power back in
When back In openelec the remote doesn't work anymore
Why ?
To fix this I have to remove remote.conf and reboot, copy remote.conf back to \Configfiles\ and reboot
Now the remote works again
But when I unplug the power cable again, the remote stops working
Hope someone can help me out here to fix this issue
Why ?
Try the the other of whatever you used.
Originally posted by kostaman View PostYou have not told us which version you installed MXQ ARM or HD18Q ?
Using: 6.0.3.5 / OpenELEC-Amlogic.MXQ.arm-6.0.3.5
Did this fix a remote issue for you ? or just a suggestion ?
Originally posted by topher67 View PostHow are people finding the Jarvis version compared to Isengard?
Worth updating or shall I stick with the 15.2 version for now?
I prefer to use Jarvis.
For some odd reason with Isengard, the program guide for Live TV is always 1 hour advanced. If I reset it, it eventually goes back this way.
Strangely, the system time and time zone is correct, and TVHeadend shows the correct program guide for the time.
Jarvis also appears to start the Live TV stream much faster than Isengard.
As Sonofdinah mentioned, scaling does seem a bit better and appears to stretch 4:3 to 16:9 well.
There are currently 2152 users online. 2 members and 2150 guests.
