[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by PatrickJB View PostTwo new builds should be out soon, one for Isengard and o beta for Jarvis, that sort the skin problem. As for the sound problem I'm not sure, perhaps somebody else here has a solution for that. Sound works fine on my MXQ, I don't know the board number as I haven't opened my box up yet. There are test builds of the new versions a page or two back if you want to try them.
ok update... i have 2 mxq first one v.1.0 second one v.03. i installed 6.0.3.4. on v.1.0 works great but i can't use the remote that came with it, but i can use the remote that came with the v.03 and also my mx2 remote is compatible. that also goes for v.03. the problem i have with v.03 is still no sound. if i unplug the cdmi and plug it back in while its on then i get sound or if change the input or source to where i had the hdmi at again then ill get sound. hope this helps thanks for the hard work that was put in to this.
Originally posted by smilez View Postok update... i have 2 mxq first one v.1.0 second one v.03. i installed 6.0.3.4. on v.1.0 works great but i can't use the remote that came with it, but i can use the remote that came with the v.03 and also my mx2 remote is compatible. that also goes for v.03. the problem i have with v.03 is still no sound. if i unplug the cdmi and plug it back in while its on then i get sound or if change the input or source to where i had the hdmi at again then ill get sound. hope this helps thanks for the hard work that was put in to this.
Originally posted by Pravsovet View PostI use 6.0.3.4 HD18Q version on all-black-mxq. Now boot is reliable. But sometives I've got new issue. Sometimes Kodi settings no saved. System start at default settings. What is it?
Originally posted by kszaq View PostThis is an issue I introduced somewhere in 6.0.3.2 or 6.0.3.3... To resolve it, please use this test build: http://s805.eu/test/6.0.3.5-build1/ A fix will be included in next stable build.
Another thing. When my provider has changed settings for iptv, my box has stopped work with TV. Box don't understand name of server in TV playlist. Server not ping by name, only by IP. I've changed playlist replacing name on IP adress. TV works. But I have to edit playlist, when provider has changed it.Attached Files
This don't work for me. There is the same problem. Log attached.
Quoting K from the download page:
"- DVB support is experimental, some USB DVB tuners don't work at all"
Originally posted by Pravsovet View PostThis don't work for me. There is the same problem. Log attached.
About DNS issue, can you ping that server by name from your computer? There is nothing in the log about unsuccessful DNS query.
Originally posted by Raugo View PostHello, I have this rom installed on my mk808b+ but I like to disable the automatic channel change of the cec. I need the cecb-no-automatic-tv-turn-on-off.zip but i dont find it, anyone have it?
New releases before I disappear for a week: 6.0.3.5 and 6.95.1.1. Uploading now.
Cummulative changelog:- fixed settings being reset on reboot (hopefully)
- fixed not being able to boot from SD card after installing OE on NAND
- fixed kernel log showing for a moment before OE splash
- added u-boot-tools with patches to make it possible to change u-boot variables from command line
- added experimental mt7610u driver
- re-added an option in Confluence to reboot from NAND (you can also reboot from command line by entering rebootfromnand)
- you need to reapply aml_autoscript to make reboot from NAND work
- fixed standby for MXQ with factory bootloader
- fixed a bug in hotplug governor to bump performance under high loads
- if you lost your original aml_autoscript file or want to use it with previous releases, it's available at:http://s805.eu/releases/boot_from_sd_uenv/
- to change default CEC settings, login over SSH and enter:
- fw_setenv cecconfig cec0 to turn off CEC completely
- fw_setenv cecconfig cecb to disable auto-standby
- fw_setenv cecconfig cecf to fully enable CEC
MXQ box: ping: bad address 'ott.local'. But with IP ping is OK.
There is nothing in the log because I've edit TV playlist replacing name on IP adress.. With IP adress IPTV works.
There are currently 2389 users online. 0 members and 2389 guests.
