[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by kostaman View Post
Originally posted by evolovey2k View Post
Thanks a lot. I understand. I have no problems with LibreELEC powering off and powering on the box. When the box is on the LED is red and when it is turned off the LED either goes blue or stays red. Do you think you could provide some guidance on finding a factory firmware for my board S805_MXQ_V2.1_150516? Any help will be greatly appreciated. Kind regards.
I found the firmware that works perfectly with my board (S805_MXQ_V2.1_150516). Here is the link:
https://mega.nz/&usg=ALkJrhieX6R__SK...OfK77W1TtmqBwo
or: https://yadi.sk/d/cyaNjkPmkaQuo
Does anyone have a copy of the releases? I tried to download today and cant seem to get anywhere with it... this is exactly what i need.. a barebones system with literally just Kodi for the GUI...
Looking for the OpenElec versions but so far only thing I think I'll be able to use is the LibrElec versions....
EDIT:
Anyone willing to help me mod this box?? I have a MXV S805P ...
Current Firmware: 20160222
"Kodi 15.2 - isengard - rc" reports the following:
AMLogic Meson8B
Revision 000a
ARMv7 Rev 1 (v71)
Current OS: Android 4.4.2 API Level 19 (kernel: Linux 3.10.33)
Screen Res: [email protected] - Full Screen
OpenGL: ARM - OpenGL ES 2.0
Originally posted by twixtedchaox View PostDoes anyone have a copy of the releases? I tried to download today and cant seem to get anywhere with it... this is exactly what i need.. a barebones system with literally just Kodi for the GUI...
EDIT:
AMLogic Meson8B
Revision 000a
ARMv7 Rev 1 (v71)
https://www.dropbox.com/sh/jrjtw4n1gq9k96r/AADuSd4KKHumbjtDmM9EpMMha?dl=0Last edited by clarkss12; 05 September 2017, 18:04.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Here is the link to my OpenELEC firmware for my MK808B+, which should work for you. It is for microSD card install, just extract the 3 files and copy them to the root of your microSD card.
https://www.dropbox.com/sh/mqegjnuz2...CLr6bnXva?dl=0
Originally posted by RC_cat View Post
Hi, can u reshare the firmware please?
ThanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
UPDATE:
There are currently 3154 users online. 0 members and 3154 guests.
