I read somewhere that using the command 'touch /storage/.please_resize_me' via ssh would allocate the rest of the cards storage for user data?
[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by kszaq View Post
I read somewhere that using the command 'touch /storage/.please_resize_me' via ssh would allocate the rest of the cards storage for user data?All Black MXQ
Working OpenELEC -OpenELEC-Amlogic.m201d.arm-6.95.2.2-devel-20160419155042-r22630-g8a99467.img.xz On SD
Working Android img - cyx_MXQ_8189etv_8g1g_kodi_addons_160126_SD升级.rar
Board Number: MXQ S805 V3_1 20151230
Originally posted by kiwi_man82 View Post
Ah ha. So even thou the card shows only having one active partition on a disk manager tool oe/le does actually mount and use the reset of the storage available on the sd card. I just guessed since it wasn't active when writing the image in windows it reformatted the sd card to only be a 512meg card and didn't use the other 400ish meg of storage. Well I guess I will have to find a bigger card then 😂😂
All Black MXQ
kiwi_man82 I have a MXQ V3_1 20151230 board and I can get it to boot but no WiFi. Is WiFi working with OE on your box?
Frank
Originally posted by MinixCrazy View PostGuest I have a MXQ V3_1 20151230 board and I can get it to boot but no WiFi. Is WiFi working with OE on your box?
FrankAll Black MXQ
Originally posted by MinixCrazy View Postkiwi_man82 I have a MXQ V3_1 20151230 board and I can get it to boot but no WiFi. Is WiFi working with OE on your box?
Frank
Frank
I wasn't able to test the OE roms for the m201d but I guess they work just the same.
Originally posted by bossydale View Postloving your work buddy thanks. Does anybody know which build reportedly works on the all black MXQ?Originally posted by mwp1 View Post
For all black MXQ, you should use HD18Q build.
I haven't got around to extract the device tree and merge that with other builds to see if that would work, but it's on my todo list...
Originally posted by Spekkie View PostNot true. This depends on your board. I have an all black MXQ with V3_1 20151230 board and the only build that worked for me (form SD, did not test NAND) was the m201d build. However that build reports a wrong ram amount for the device.
Originally posted by kszaq View PostV3_1 20151230 board has only 512MB of RAM. Android firmware for that board is faking RAM amount. You can read my findings in LE thread.
Is there a way in android to verify the real amount of ram? Like apps or some other trick?
(can't post yet in the LE forum so I ask here...)
I've read your posts in the LE thread and got one question left:
(can't post yet in the LE forum so I ask here...)Code:DRAM bank = 0x00000000 -> start = 0x00000000 -> size = 0x40000000
Code:DRAM bank = 0x00000000 -> start = 0x00000000 -> size = 0x20000000
There are currently 2042 users online. 0 members and 2042 guests.
