Found this and the guy says it's not optical so I still don't understand why you get a blue light: http://forum.androidgadget.co.uk/sho...pid=579#pid579
Did you have a look to see if your TV have an optical out?
EDIT: Yes you need a cable like this, note it's coaxial not optical, although someone on that thread did say the digital audio signal come out of one of the AV cables connectors: https://www.amazon.co.uk/FiiO-L21-Co...+coaxial+cable
And if your sound bar only has optical input and no coaxial then yes you'll need a converter box. Make sure you TV doesn't have an optical out as most modern TV's do which is why sound-bars have optical inputs.
EDIT 2: And just for clarity the digital audio sent through the HDMI cable, will pass through the TV if it has a optical out, I used to use this and it worked fine. .
